StarTech.com USB 3 to Fiber Optic Converter
Quicklinx: DFR4WS00 Mfr#: US1GA30SXSC
Wired / Wireless: Wired
Protocol: Gigabit Ethernet
Type: Network adapter
24 in stock
£210.07 ex VAT
£252.08 inc VAT
  • Fiber-optic SC port
    The USB to fiber-optic converter is equipped with an optical transceiver for 1000Base-SX networks, providing network connectivity with a maximum range of 550 m over multimode fiber.
  • Secure fiber-to-the-desk connectivity
    This USB to fiber converter provides reliable connectivity while protecting your network from problems with electronic interference - a common issue with RJ45 networks. Fiber-to-the-desk connectivity (FTTD) maximizes network security, reducing the risk of data leaks for sensitive information, without compromising network speed and reliability.
  • Easy portability
    Compact and portable, this USB 3.0 fiber-optic converter is powered directly from the USB port, making it easy to connect when you're on the go.
  • Plug and play
    Get up and running quickly. The converter supports certified drivers for Windows, Mac and Linux. When you plug the adapter into a USB port, you simply install the drivers and the adapter is ready to transmit over a fiber network.
StarTech.com USB to Fiber Optic Converter - 1000Base-SX SC - MM - Windows / Mac / Linux - USB 3.0 Ethernet Adapter - Network Adapter (US1GA30SXSC) - network adapter
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
1000Base-SX
5.5 cm 2 cm
Length
26 cm
100 g
Cabling Type
Ethernet 1000Base-SX
GigE
Max Transfer Distance
550 m
Data Transfer Rate
1 Gbps
Jumbo frame size: 9000
IEEE 802.3z, IEEE 802.1Q
Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 3.5 to 4.11.x LTS versions, Microsoft Windows Server 2019, Apple MacOS X 10.9 - 10.14
Network adapter
External
SuperSpeed USB 3.0
Ports
1000Base-SX
Wired
Cabling Type
Gigabit Ethernet
Data Transfer Rate
1 Gbps
550 m
Optical Wave Length
850 nm
Status Indicators
Power, link/activity
Full duplex capability, USB powered, Jumbo Frames support
1 x 1000Base-SX - SC multi-mode - female
1 x USB cable (integrated) - 19.5 cm
FCC, RoHS, WEEE
5.5 cm
2 cm
Length
26 cm
100 g
Shipping Weight
120 g
60 °C
5 - 90%
DFR4 StarTech.com Gigabit Ethernet Multi Mode Fiber Media Converter SC 550m - 1000 Mbps In Stock £116.43
DFR4 StarTech.com Fiber Media Converter - w/ SFP In Stock £88.03
DFR4 StarTech.com USB 3 to Fiber Optic Converter In Stock £210.07
DFR4 StarTech.com USB 3 Fiber Converter Open SFP In Stock £172.89
DFR4 StarTech.com USB 2.0 to Fiber Converter In Stock £122.71
DFR4 StarTech.com USB C to Fiber Optic Converter In Stock £177.54
Price Range Ex VAT: 150 - 300
