Turn a 6 Gbps HDD or SSD into secure external storage with touchpad password entry. The S2510BU33PW USB 3.0 encrypted hard drive enclosure lets you to turn your 2.5-inch SATA hard drive (HDD) or solid state drive (SSD) into an AES-encrypted external drive.
To ensure all of the data on your drive is protected from unauthorized access, the secure enclosure uses an Advanced Encryption Standard Algorithm (256-bit AES). Once your encryption is set, access to the content is only authorized through a customized PIN that you set and enter using the sleek built-in touchpad. The encryption is hardware based, eliminating the hassle of complicated software installation and configuration.
The hard drive enclosure ensures maximum performance, with support for USB 3.0 transfer speeds up to 5 Gbps. The enclosure also supports SATA III drives, ensuring you can still achieve high performance while accessing your SATA 6 Gbps SSD externally.
- StarTech.com USB 3.0 Hard Drive Enclosure - Encrypted SATA Hard Drive to USB - HDD/SSD Enclosure with Password Protection (S2510BU33PW) - storage enclosure - SATA 6Gb/s - USB 3.0
- Storage enclosure - external
- Bus Type
- USB 3.0
- Black
- Expansion Bays
- 1 x internal - 2.5"
- Hard Drive Form Factor Compatibility
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive, solid state drive
- Max Storage Devices Qty
- 1
- Product Material
- Plastic, steel
- 7.7 cm x 12.3 cm x 1.4 cm
- 94 g
- 2-year warranty
- 2.5"
- Hard Drive Maximum Height
- 9.5 mm
- Host Bus
- USB 3.0
- Product Material
- Plastic, steel
- Black
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- 1
- Bays
- 1 x SATA 6Gb/s - SATA combo
- Connections
- 1 x USB 3.0 - 9 pin USB Type A
- Included Accessories
- Carrying case, screwdriver, screws
- Cables Included
- 1 x USB cable - external
- USB powered, status OLED display, tested with up to 1TB 5400 RPM hard drives, touchpad
- Plug and Play, AES-256
- Limited warranty - 2 years
- 7.7 cm
- 12.3 cm
- 1.4 cm
- 94 g
- 0 °C
- 40 °C
