StarTech.com USB 3.1 USB-C to USB-A Adapter
Quicklinx: BFPCWS00 Mfr#: USB31CAADP
More than 50 in stock
£9.31 ex VAT
£11.17 inc VAT
Connect your USB Type-C device to a USB Type-A device, with this durable adapter. Have you purchased a new device that only came equipped with a USB Type-C or Thunderbolt 3 port, such as a laptop or tablet? Do you need to connect to older USB 3.0 or 2.0 devices?
This USB-C to USB-A adapter makes it easy to connect USB 3.0 and 2.0 devices to new USB-C devices. Simply plug the adapter into the USB Type-C port to turn it into a USB Type-A port, and you're ready to connect your older devices. The adapter is compatible with USB 3.0 enabled computers, such as the Dell Latitude 11 5000 2-in-1, and more.
USB 3.0 is also known as USB 3.1 Gen 1 (5Gbps).
StarTech.com 6in USB C to A Adapter Cable M/F - USB 3.0 - USB-IF Certified - USB-C adapter - 15.2 cm
USB-C adapter
Double shielded
Length
15.2 cm
Connector
24 pin USB-C - male
Connector (Second End)
9 pin USB Type A - female
USB 3.0
Apple MacBook
USB-C adapter
Double shielded
Plated Connector
Nickel
Length
15.2 cm
Connector
24 pin USB-C - male
USB 3.0, RoHS, USB-IF
Apple MacBook
BFPC StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £9.31
BFPC StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £9.41
BFPC StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £10.36
BFPC StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.26
BFPC StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £7.54
BFPC StarTech.com 1m USB 2.0 USB-C to USB-B Cable In Stock £12.59
BFPC StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £14.87
Price Range Ex VAT: 0 - 50
