Brand
StarTech.com USB 3.1 Tool-free Enclosure
Quicklinx: BGC1WS00 Mfr#: S251BPU313
Type: Storage enclosure
HD Size: 2.5"
12 in stock
£23.36 ex VAT
£28.03 inc VAT
Get the faster speed of USB 3.1 Gen 2 in a lightweight and portable storage solution. Now it's easier than ever to access your data wherever you go. This USB 3.1 Gen 2 (10 Gbps) single-drive enclosure for 2.5" solid-state or hard drives gives you an ultra-fast, portable external storage solution.
Engineered with a durable and lightweight housing, the enclosure tucks easily into a laptop bag or carrying case for portable storage. It's completely tool-free so you can install your drives quickly on the fly.
USB 3.1 Gen 2 gives you greater bandwidth and speed with file transfer rates of up to 10 Gbps - twice the speed of USB 3.0 (USB 3.1 Gen 1) technology. It lets you leverage the high performance of the latest SSDs and hard drives, while alleviating bottlenecks in your data transfer.
The enclosure connects easily to a host computer, with no external power required. It comes with a USB A to Micro B cable, providing backward compatibility with existing USB ports or hardware. It also provides UASP support for enhanced performance.
StarTech.com USB 3.1 (10Gbps) Tool-free Enclosure for 2.5" SATA Drives - Ultra-fast, Portable Data Storage - Lightweight Plastic (S251BPU313) - storage enclosure - SATA 6Gb/s - USB 3.1 (Gen 2)
Storage enclosure - external
Bus Type
USB 3.1 (Gen 2)
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 6Gb/s
Data Transfer Rate
10 GBps
Supported Devices
Hard drive, solid state drive
Product Material
Plastic
Power Source
USB bus
8.8 cm x 13.2 cm x 1.5 cm
70 g
P/N: BNDTBUSB3142, HB30C3A1CFB, HB30C3A1CFS, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311AC2, PEXUSB311EI, PEXUSB312A2, PEXUSB314A2V, PEXUSB314A2V2
2.5"
Hard Drive Maximum Height
9.5 mm
Host Bus
USB 3.1 (Gen 2)
Product Material
Plastic
Storage Controller
SATA 6Gb/s
Data Transfer Rate
10 GBps
Supported Devices
ASMedia ASM1351
Bays
1 x internal - 2.5"
1 x SATA 6Gb/s - SATA combo
1 x USB 3.1 (Gen 2) - 10 pin Micro-USB Type B
HDD pad
1 x USB cable - external
USB powered, LED indicator, UASP transfer protocol, tested with up to 2TB 7200 RPM 2.5" hard drives
FCC, RoHS
Power Source
USB bus
8.8 cm
13.2 cm
1.5 cm
70 g
10 - 95%
BGC1 StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - M/M In Stock £6.84
BGC1 StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £6.39
BGC1 StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £25.04
BGC1 StarTech.com USB 3.1 Gen 2 Single-bay Dock In Stock £50.08
BGC1 StarTech.com USB 3.1 Tool-free Enclosure In Stock £23.36
BGC1 StarTech.com USB 3.1 Gen 2 Dual-bay Dock In Stock £81.14
BGC1 StarTech.com USB 3.1 Gen 2 Adapter Cable In Stock £15.42
BGC1 StarTech.com USB 3.1 Gen 2 Enclosure In Stock £39.96
BGC1 StarTech.com StarTech.com 2-Port 10Gbps USB-A/USB-C PCIe Card -USB 3.1 In Stock £38.45
HD Size: 2.5"
Stock Status: In stock
