StarTech.com USB 3.1 mSATA Drive Enclosure
Quicklinx: C53PWS00 Mfr#: SMS1BMU313
£31.29 ex VAT
£37.54 inc VAT
Turn your mSATA or mSATA Mini drive into a portable, high performance storage solution over USB 3.1 Gen 2. Add high-speed data storage to your laptop or desktop computer, with this portable mSATA and mSATA Mini drive enclosure. It gives you fast data transfer speeds with USB 3.1 (10Gbps) in a solid aluminum enclosure.
With its compact design and metal housing, the mSATA drive enclosure gives you a highly portable, high-speed storage solution. Slim and stylish, the enclosure makes the ideal accessory for laptop or desktop computers.
The mSATA enclosure provides dependable drive protection with its durable, solid aluminum housing. It also features ventilation holes to help protect your drive from overheating by allowing heat to dissipate and help maintain an optimum operating temperature.
With support for USB 3.1 (also known as USB 3.1 Gen 2) and SATA III (6Gbps) host connections, the drive enclosure lets you maximize the performance of your mSATA solid-state drives to achieve greater data transfer speeds. The mSATA drive enclosure also supports UASP for enhanced performance.
This portable drive enclosure is compatible with all standard mSATA drives, including the mSATA Mini (Half-Size) form factor.
StarTech.com USB 3.1 Gen 2 (10Gbps) Enclosure - Portable mSATA SSD Enclosure - Aluminum mSATA Drive Enclosure with UASP (SMS1BMU313) - storage enclosure - SATA 6Gb/s / mSATA - USB 3.1 (Gen 2)
Storage enclosure - external
Bus Type
USB 3.1 (Gen 2)
Black, silver
Expansion Bays
1 x internal - mSATA
Hard Drive Form Factor Compatibility
mSATA, mSATA mini
SATA 6Gb/s / mSATA
Data Transfer Rate
6 Gbit/s
Supported Devices
Solid state drive
Max Storage Devices Qty
1
Product Material
Aluminium
Power Source
USB bus
4.15 cm x 9.85 cm x 1.2 cm
55 g
mSATA, mSATA mini
Hard Drive Maximum Height
50.8 mm
Host Bus
USB 3.1 (Gen 2)
Product Material
Aluminium
Black, silver
Storage Controller
SATA 6Gb/s / mSATA
Data Transfer Rate
6 Gbit/s
Supported Devices
Solid state drive
1
ASMedia ASM1351
Bays
1 x mSATA - mSATA (internal)
1 x USB 3.1 (Gen 2) - 9 pin Micro-USB Type B
Screwdriver, 4 x screws
1 x micro-USB to USB cable - external
LED indicator, UASP transfer protocol, ventilation holes, tested with up to 1TB mSATA drives
FCC, RoHS, WEEE, RCM
Power Source
USB bus
4.15 cm
9.85 cm
1.2 cm
55 g
