Quicklinx: BKBZWS00 Mfr#: S351BU313
Type: Storage enclosure
HD Size: 3.5"
32 in stock
£35.88 ex VAT
£43.05 inc VAT
The high-speed, high-capacity data storage solution you've been waiting for - with USB 3.1 Gen 2. Now, get the speed and capacity you want in external data storage. This single-drive enclosure for 3.5" SATA hard drives gives you high-speed USB 3.1 Gen 2 (10 Gbps) performance with a large drive capacity of up to 6TB.
USB 3.1 Gen 2 gives you greater bandwidth and speed with file transfer rates of up to 10 Gbps - twice the speed of USB 3.0 (USB 3.1 Gen 1) technology. It lets you leverage the high performance of the latest SSHDs and hard drives, while alleviating bottlenecks in your data transfers.
The clean and simple design makes this enclosure the perfect desktop companion for your Mac or PC. It's made of durable aluminum with a fan-less design that ensures quiet operation. It also comes with a vertical stand so it occupies minimal space in your work area.
This versatile enclosure comes with a USB Type A-to-B cable, providing backward compatibility with existing USB ports or hardware. It also provides UASP support for enhanced performance.
StarTech.com USB 3.1 (10Gbps) Enclosure for 3.5" SATA Drives - storage enclosure - SATA 6Gb/s - USB 3.1 (Gen 2)
Storage enclosure - external
Bus Type
USB 3.1 (Gen 2)
Expansion Bays
1 x internal - 3.5"
Hard Drive Form Factor Compatibility
3.5"
SATA 6Gb/s
Data Transfer Rate
10 GBps
Supported Devices
Hard drive
Product Material
Aluminium
Power Source
USB bus
7.7 cm x 12 cm x 1.55 cm
130 g
3.5"
Hard Drive Maximum Height
9.5 mm
Host Bus
USB 3.1 (Gen 2)
Product Material
Aluminium
Storage Controller
SATA 6Gb/s
Data Transfer Rate
10 GBps
Supported Devices
Hard drive
ASMedia ASM1351
Bays
1 x internal - 3.5"
1 x SATA 6Gb/s - SATA combo
1 x USB 3.1 (Gen 2) - 9 pin USB Type B
Screwdriver, 4 x screws
1 x USB cable - external
LED indicator, tested with up to 6TB 7200 RPM hard drives, UASP transfer protocol
FCC, RoHS
Power Source
USB bus
7.7 cm
12 cm
1.55 cm
130 g
5 - 95%
BKBZ StarTech.com 1 ft SuperSpeed USB 3.0 Cable A to B - M/M In Stock £5.08
BKBZ StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £7.03
BKBZ StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £24.61
BKBZ StarTech.com USB 3.1 Gen 2 Single-bay Dock In Stock £43.00
BKBZ StarTech.com USB 3.1 Tool-free Enclosure In Stock £20.46
BKBZ StarTech.com USB 3.1 Gen 2 Dual-bay Dock In Stock £69.69
BKBZ StarTech.com USB 3.1 Gen 2 Adapter Cable In Stock £14.45
BKBZ StarTech.com USB 3.1 Gen 2 Enclosure In Stock £35.88
HD Size: 3.5"
Price Range Ex VAT: 0 - 50
