StarTech.com USB 3.0 Video Capture Device - HDMI / DVI / VGA / Component HD Video Recorder
Quicklinx: 9YYBWS00 Mfr#: USB3HDCAP
Type: Video Adapter
Compatibility: PC
Interface: USB
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
£168.56 ex VAT
£202.27 inc VAT
Capture a High-Definition HDMI, DVI, VGA, or Component Video source to your PC. This USB 3.0 external video capture device lets you record 1080p HD video and stereo audio to your computer system. With multiple video inputs including HDMI, DVI, VGA and component, the capture card can record original content from various sources such as computers, camcorders, security systems, POS terminals, and servers. With a framerate of 60 FPS (frames per second) and H.264 encoding, this is the perfect solution for capturing high-definition video for editing, compiling, and archiving.
Record lossless video at 60 FPS ensuring every frame of content is saved, unlike 30-frame-per-second capture devices that only catch half the action. 60 FPS exactly matches the output of most computer video cards, which is great for recording the output from your PC, server, or POS station when creating software training and tutorial videos.
The included software encodes in H.264, the most widely adopted video codec in the world, ensuring your video captures will be compatible with almost any device platform such as PC, Mac, iOS and Android with no editing or converting required. H.264 is also widely supported by most software titles including Adobe Premiere and Windows Media Encoder. Plus, the software not only lets you capture and export videos, but it also lets you take screenshots, schedule recordings and instantly stream your video source over the Internet using online services such as Twitch or Justin.TV.
This USB capture card is capable of capturing lossless raw video making it compatible with Microsoft DirectShow. With raw video capture you can record video using your preferred third party DirectShow software such as Open Broadcaster Software (OBS).
With multiple A/V input options you can capture from a wide variety of sources including HDMI, DVI, VGA, and component. You can also use this capture card with A/V adapters to record other video sources such as SDI using the SDI to HDMI converter (SDI2HD). Support for a variety of A/V device is ideal for archiving analog video footage into a digital database.
The device also includes easy-to-use software that's compatible with NTSC and PAL systems, making it a must for professional video archiving applications where source media can change from project to project.
Will not record digitally encrypted content. Not compatible with ASmedia, or Etron USB 3.0 host controllers. If your system has one of these non-supported controllers you can alternatively add a PCI-express USB 3.0 controller card such as the StarTech.com PEXUSB3S4V, PEXUSB3S23, PEXUSB3S400 or PEXUSB3S4.
  • Seamless picture quality at 60 frames per second
    The USB3HDCAP lets you externally capture uncompromised high-definition video to your computer at 60 FPS, through a USB 3.0 connection. With the included software, you can instantly stream your video source using online services. This unprecedented performance opens up new possibilities for external video game capture, when used with a 2-port HDMI splitter such as ST122HDMILE. Now, you'll be able to record every frame of your video game experience in high-definition 1080p using any USB 3.0-equipped PC, while playing on different a screen.
  • High-performance onboard encoding
    With onboard encoding, the video conversion process functions independently of your computer resources to maintain system performance. Plus, since software encodes in H.264, the most widely adopted video codec in the world, your video files will be natively compatible with almost any media device such as iOS or Android -smartphones and tablets.
  • Flexible input solutions for convenient compatibility
    With multiple A/V input options you can capture from a wide variety of devices. This versatile USB 3.0 external capture device supports HDMI, DVI, VGA, and Component video inputs, making it the ideal solution for capturing training or tutorial videos from a variety of different computer A/V outputs.
StarTech.com HDMI Video Capture Device - 1080p - 60fps Game Capture Card - USB Video Recorder - with HDMI DVI VGA (USB3HDCAP) - video capture adapter - USB 3.0
Video capture adapter
Interface Type
USB 3.0
11.44 cm x 8.39 cm x 2.45 cm
170 g
Video Input
S-video input, composite video/audio input, component video input, VGA input, DVI-Analogue/Digital input, HDMI input
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Analogue Video Format
NTSC, PAL, PAL-M, PAL 60
Analogue video Signal
S-Video, composite video
Digital Video Format
MPEG-4, H.264
Audio Input Support
Standard
16:9 widescreen mode
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
Interface Type
USB 3.0
11.44 cm
8.39 cm
2.45 cm
170 g
Video
Interface Type
Video Modes
MPEG-4, H.264
Audio Input Support
Standard
1 x display / video - component video input - RCA x 3 - on cable , 1 x display / video - S-video input - 4 pin mini-DIN - on cable , 1 x audio - line-In - RCA x 2 - on cable , 1 x display / video - HDMI input - 19 pin HDMI Type A , 1 x display / video - DVI-Analogue/Digital input - 24+5 pin combined DVI , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) - on cable , 1 x display / video - composite video input - RCA - on cable
1 x SuperSpeed USB 3.0 - 9 pin USB Type B
1 x A/V cable - external , 1 x SuperSpeed USB cable - external , 1 x DVI-VGA adapter - external
FCC, RoHS
Software Included
Drivers & Utilities
System Requirements Details
Core i3 - 2.8 GHz - RAM 2 GB
9YYB StarTech.com 20 ft DVI-I Dual Link Digital Analog Monitor Cable M/M In Stock £21.25
9YYB StarTech.com PCIe HDMI & VGA Capture Card In Stock £138.60
9YYB StarTech.com HDMI Capture Card - PCIe - UHD 4K 60Hz - For Windows In Stock £303.52
Type: Video Adapter
Compatibility: PC
Interface: USB
