StarTech.com USB 3.0 to VGA External Video Card Multi Monitor Adapter with 1-Port USB Hub  1920x1200
Quicklinx: 8NVBWS00 Mfr#: USB32VGAEH
28 in stock
£40.35 ex VAT
£48.42 inc VAT
Connect a VGA-equipped display through USB 3.0, while keeping the USB 3.0 port available. The USB32VGAEH USB 3.0 to VGA Adapter turns a USB 3.0 port into a VGA output port with 1920x1200 (WUXGA) video support. The adapter features a built-in 1-Port USB 3.0 hub, which offers a connection port in place of the USB port used for connecting the VGA adapter - an ideal workaround for Ultrabook or laptop users where only a limited number of USB ports are available.
Functioning as an external graphics card, this USB to VGA adapter provides a convenient way to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0).
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter delivers smooth, high-definition content to your VGA display / projector. The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
StarTech.com USB 3.0 to VGA External Video Card Adapter with 1-Port USB Hub - external video adapter - T5-302 - 16 MB - black
External video adapter
Bus Type
SuperSpeed USB 3.0
Graphics Engine
MCT Trigger 5 T5-302
16 MB DDR2
Max Resolution
1920 x 1200
VGA , USB 3.0
4.9 cm x 8.5 cm x 1.7 cm
Enclosure Colour
Bus Type
SuperSpeed USB 3.0
Graphics Engine
Max Resolution
1920 x 1200
VGA , USB 3.0
USB powered, USB Pass-Through
Size
16 MB
DDR2 SDRAM
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
Min Processor Type
Intel Core i3 2.8 GHz
Min RAM Size
2 GB
Additional Requirements
USB port
1 x SuperSpeed USB cable - 16 cm
Software Included
Drivers & Utilities
WHQL, FCC
4.9 cm
8.5 cm
1.7 cm
75 g
Enclosure Colour
50 °C
0 - 85% (non-condensing)
8NVB StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.74
8NVB StarTech.com 6 ft Monitor VGA Cable - HD15 M/M In Stock £4.11
8NVB StarTech.com 15 ft Monitor VGA Cable - HD15 MM In Stock £5.03
8NVB StarTech.com 6 ft SuperSpeed USB 3.0 Cable A to A - M/M In Stock £6.16
8NVB StarTech.com 6 ft Black SuperSpeed USB 3.0 Cable A to A - M/M In Stock £6.16
8NVB StarTech.com 3m 10ft USB 3.0 A to A Cable In Stock £6.60
Price Range Ex VAT: 0 - 50
