Connect a VGA-equipped monitor/projector through USB 3.0, and add three additional USB devices to the same USB 3.0 port with a built-in 3-port USB 3.0 hub. The USB32VGAEH3 USB 3.0 to VGA Adapter turns a USB 3.0 port into a VGA output port with 1920x1200/1080p video support. The adapter features a built-in 3-port USB 3.0 hub, which enables you to connect three different USB devices, along with the display adapter, to the same USB 3.0 port - an ideal workaround for Ultrabook or laptop computers that have a limited number of USB ports available.
Functioning as an external graphics card, this USB to VGA adapter provides a convenient way to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer. Leveraging the high-bandwidth (5 Gbps) USB 3.0 interface, the adapter delivers smooth, high-definition content to your VGA monitor / projector. The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
The USB32VGAEH3 also features a built-in 3-port USB 3.0 hub, which lets you use the device as a mini dock for connecting peripherals such as a mouse, printer and keyboard along with your monitor. Then, it's as easy as connecting your laptop to the adapter to sync each device at your work station - a versatile solution for making your laptop portable when you want it to be, and powerful when you need it to be.
- StarTech.com USB 3.0 to VGA External Graphics Adapter with 3-Port USB Hub - external video adapter - T5-302 - 16 MB - black
- External video adapter
- Bus Type
- SuperSpeed USB 3.0
- Graphics Engine
- MCT Trigger 5 T5-302
- Memory
- 16 MB DDR2
- Max Resolution
- 1920 x 1200
- Interfaces Details
- VGA , 3 x USB 3.0
- 4.4 cm x 23.5 cm x 1.4 cm
- Enclosure Colour
- Black
- 2-year warranty
- Designed For
- P/N: MXT101MM
- Bus Type
- Graphics Engine
- Max Resolution
- 1920 x 1200
- VGA , 3 x USB 3.0
- USB powered, USB Pass-Through
- Size
- 16 MB
- Technology
- DDR2 SDRAM
- Cables Included
- 1 x SuperSpeed USB cable - 15.3 cm
- WHQL, FCC, RoHS
- 4.4 cm
- 23.5 cm
- 1.4 cm
- 212 g
- Enclosure Colour
- Black
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 0 - 85% (non-condensing)
- Designed For
- P/N: MXT101MM
