Your basket is empty
StarTech.com USB 3.0 to VGA External Multi Monitor Graphics Adapter with 3-Port USB Hub
Quicklinx: 9PRNWS00 Mfr#: USB32VGAEH3
Connect a VGA-equipped monitor/projector through USB 3.0, and add three additional USB devices to the same USB 3.0 port with a built-in 3-port USB 3.0 hub. The USB32VGAEH3 USB 3.0 to VGA Adapter turns a USB 3.0 port into a VGA output port with 1920x1200/1080p video support. The adapter features a built-in 3-port USB 3.0 hub, which enables you to connect three different USB devices, along with the display adapter, to the same USB 3.0 port - an ideal workaround for Ultrabook or laptop computers that have a limited number of USB ports available.
Functioning as an external graphics card, this USB to VGA adapter provides a convenient way to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer. Leveraging the high-bandwidth (5 Gbps) USB 3.0 interface, the adapter delivers smooth, high-definition content to your VGA monitor / projector. The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
The USB32VGAEH3 also features a built-in 3-port USB 3.0 hub, which lets you use the device as a mini dock for connecting peripherals such as a mouse, printer and keyboard along with your monitor. Then, it's as easy as connecting your laptop to the adapter to sync each device at your work station - a versatile solution for making your laptop portable when you want it to be, and powerful when you need it to be.
StarTech.com USB 3.0 to VGA External Graphics Adapter with 3-Port USB Hub - external video adapter - T5-302 - 16 MB - black
External video adapter
Bus Type
SuperSpeed USB 3.0
Graphics Engine
MCT Trigger 5 T5-302
16 MB DDR2
Max Resolution
1920 x 1200
VGA , 3 x USB 3.0
4.4 cm x 23.5 cm x 1.4 cm
Enclosure Colour
2 years warranty
Bus Type
SuperSpeed USB 3.0
Graphics Engine
Max Resolution
1920 x 1200
VGA , 3 x USB 3.0
USB powered, USB Pass-Through
Size
16 MB
DDR2 SDRAM
1 x SuperSpeed USB cable - 15.3 cm
WHQL, FCC, RoHS
4.4 cm
23.5 cm
1.4 cm
212 g
Enclosure Colour
50 °C
0 - 85% (non-condensing)
9PRN StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.73
9PRN StarTech.com 6 ft Monitor VGA Cable - HD15 M/M In Stock £4.11
9PRN StarTech.com 15 ft Monitor VGA Cable - HD15 MM In Stock £5.03
