StarTech.com USB 3.0 to SATA or IDE Hard Drive Adapter Converter
Quicklinx: 8TJFWS00 Mfr#: USB3SSATAIDE
Type: Storage controller
  • Windows 8 (32/64 bits)
40 in stock
£28.98 ex VAT
£34.77 inc VAT
Connect a 2.5in / 3.5in SATA or IDE Hard Drive through a USB 3.0 Port. The USB3SSATAIDE USB 3.0 to IDE/SATA Adapter Cable connects any standard 2.5in or 3.5in SATA or IDE hard drive to a computer through an available USB 3.0 Port (Backward compatible with USB 2.0). The adapter lets you connect a bare drive with no enclosure, saving time and hassle.
The USB 3.0 SATA/IDE Adapter lets you externally connect a bare drive with no drive enclosure or HDD dock required, and features LED indicators that allow you to easily monitor status and activity updates.
The adapter cable works with Windows, Linux, and Mac computers and does not require any software or driver installation - a true plug-and-play solution for adding cost-effective external storage, or overcoming incompatibility between all hard drives and USB enabled motherboards that may not be SATA or IDE-equipped.
The USB3SSATAIDE USB 3.0 to IDE/SATA Adapter Cable comes complete with universal adapter and power cords, providing the additional power required to connect 3.5-inch and larger capacity 2.5-inch hard drives.
StarTech.com USB 3.0 to SATA IDE Adapter - 2.5in / 3.5in - External Hard Drive to USB Converter - Hard Drive Transfer Cable (USB3SSATAIDE) - storage controller - ATA / SATA - USB 3.0
Storage controller - external
Bus Type
USB 3.0
ATA / SATA
Data Transfer Rate
4.8 GBps
Supported Devices
Hard drive, solid state drive
Max Storage Devices Qty
3
Product Material
Plastic
Linux, Microsoft Windows 2000, Apple MacOS 8.6 or later, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
54 g
P/N: PEXUSB3S42V, PEXUSB3S44V
Host Bus
USB 3.0
Product Material
Plastic
Storage Controller
ATA / SATA
Data Transfer Rate
4.8 GBps
Supported Devices
3
1 x ATA - 40 PIN IDC , 1 x ATA - 44 PIN IDC , 1 x SATA 3Gb/s - SATA
1 x USB 3.0 - 9 pin USB Type A
Power supply, power 15 pin SATA to 4 pin adapter
1 x power 15 pin SATA to 4 pin adapter - external
LED indicator
FCC, RoHS
54 g
50 °C
5 - 85%
8TJF StarTech.com 24" Serial ATA Cable In Stock £3.57
8TJF StarTech.com 18in SATA Serial ATA Cable In Stock £3.36
8TJF StarTech.com 18in Dual Drive Ultra ATA IDE Hard Drive Cable In Stock £3.59
8TJF StarTech.com USB 2.0 to SATA/IDE Combo Adapter for 2.5/3.5" SSD/HDD In Stock £22.35
8TJF StarTech.com USB 3.0 to SATA or IDE Hard Drive Adapter Converter In Stock £28.98
8TJF StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable In Stock £8.59
8TJF StarTech.com USB 3.1 Gen 2 Adapter Cable In Stock £13.80
8TJF StarTech.com USB 3.1 Adapter Cable w/ USB-C In Stock £17.50
8TJF StarTech.com USB 3.1 2.5/3.5" SATA Adapter In Stock £29.27
8TJF StarTech.com USB C to SATA Adapter Cable In Stock £34.01
Price Range Ex VAT: 0 - 50
