The USB32HDE USB 3.0 to HDMI? Adapter turns an available USB 3.0 port into an HDMI output, with high resolution 1920x1080 (1080p) video support - a convenient external video solution that makes it easy to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0). Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter functions as an external graphics card to deliver smooth, high-definition content to your HDMI or DVI-capable display (HDMI to DVI Adapter included). The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
- StarTech.com USB 3.0 to HDMI/DVI External Video Card Multi Monitor Adapter - external video adapter - T5-302 - 16 MB - black
- External video adapter
- Bus Type
- SuperSpeed USB 3.0
- Graphics Engine
- MCT Trigger 5 T5-302
- Memory
- 16 MB DDR2
- Max Resolution
- 1920 x 1200
- HDMI , DVI-D (Single-Link) - with adapter
- 4.4 cm x 7.8 cm x 1.6 cm
- Enclosure Colour
- Black
- 2-year warranty
- Designed For
- P/N: DVIDDMM10, DVIDDMM6, DVIDSMM10, DVIMM6, DVISPL1DD, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50
- Bus Type
- Graphics Engine
- Max Resolution
- 1920 x 1200
- USB powered
- Size
- 16 MB
- Technology
- DDR2 SDRAM
- OS Required
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
- Min Processor Type
- Dual core processor 2.8 GHz
- Min RAM Size
- 2 GB
- Cables Included
- 1 x SuperSpeed USB cable - 16 cm , 1 x HDMI-DVI adapter
- FCC, RoHS
- 4.4 cm
- 7.8 cm
- 1.6 cm
- 60 g
- Enclosure Colour
- Black
- Limited warranty - 2 years
- 0 °C
- 55 °C
- 0 - 85% (non-condensing)
- Designed For
