Product
Brand
StarTech.com USB 3.0 to HDMI / DVI External Video Card Multi Monitor Adapter – 1920x1080
Quicklinx: 7TH0WS00 Mfr#: USB32HDE
  • High-Definition Multimedia Interface (HDMI)
The USB32HDE USB 3.0 to HDMI? Adapter turns an available USB 3.0 port into an HDMI output, with high resolution 1920x1080 (1080p) video support - a convenient external video solution that makes it easy to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0). Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter functions as an external graphics card to deliver smooth, high-definition content to your HDMI or DVI-capable display (HDMI to DVI Adapter included). The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
StarTech.com USB 3.0 to HDMI DVI External Video Card Multi Monitor Adapter - external video adapter - T5-302 - 16 MB - black
External video adapter
Bus Type
SuperSpeed USB 3.0
Graphics Engine
MCT Trigger 5 T5-302
16 MB DDR2
Max Resolution
1920 x 1200
HDMI , DVI-D (Single-Link) - with adapter
4.4 cm x 7.8 cm x 1.6 cm
Enclosure Colour
2 years warranty
Bus Type
SuperSpeed USB 3.0
Graphics Engine
Max Resolution
1920 x 1200
USB powered
Size
16 MB
DDR2 SDRAM
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Min Processor Type
Dual core processor 2.8 GHz
Min RAM Size
2 GB
1 x SuperSpeed USB cable - 16 cm , 1 x HDMI-DVI adapter
FCC, RoHS
4.4 cm
7.8 cm
1.6 cm
60 g
Enclosure Colour
55 °C
0 - 85% (non-condensing)
7TH0 StarTech.com 3 ft Mini USB 2.0 Cable - A to Mini B In Stock £3.18
7TH0 StarTech.com 10 ft USB 2.0 Cable - USB A to Mini B In Stock £3.31
7TH0 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £6.60
7TH0 StarTech.com 10 ft HDMI to DVI-D Cable - M/M In Stock £7.58
7TH0 StarTech.com 1 ft Mini USB 2.0 Cable - A to Mini B - M/M In Stock £3.16
