StarTech.com USB 3.0 to 4K HDMI External Multi Monitor Video Graphics Adapter
Quicklinx: 9X8ZWS00 Mfr#: USB32HD4K
More than 50 in stock
£69.51 ex VAT
£83.41 inc VAT
Connect an additional HDMI display to your PC with USB 3.0 technology capable of playback at 4K. Want to add 4K Ultra HD video to your computer system? Now, you can enjoy the picture quality of Ultra HD video, even if your system doesn't natively support 4K video output.
With an additional 4K monitor connected to your computer, you can extend or mirror your desktop for increased productivity. DisplayLink 4K Plug-and-Display certification ensures automatic driver installation, so you'll be ready to enjoy your Ultra HD display in no time.
Now you can connect a 4K HDTV, monitor or projector to your computer, even if your laptop or desktop video card doesn't natively support 4K output. The USB32HD4K USB to HDMI 4K adapter lets you extend or mirror your primary display onto an Ultra HD monitor or television, giving you the additional screen space you need to simplify multi-tasking and maximize your productivity.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television; the USB32HD4K lets you harness the impressive bandwidth capability of a USB 3.0 connection to deliver the astonishing quality of Ultra HD to your 4K display. Plus, the adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other workspace applications.
Installation has never been easier. When you connect this DisplayLink 4K Plug-and-Display certified adapter to a web-enabled Windows 7, Windows 8 or Windows 10 computer, it automatically downloads and installs the most up-to-date drivers for you, so you won't have to.
StarTech.com USB 3.0 to HDMI Adapter - DisplayLink Certified - 4K 30Hz - video interface converter - TAA Compliant - HDMI / USB - 20 cm
Cable
Video interface converter - HDMI / USB
Max Output Resolution
3840 x 2160 - 30 Hz
Length
20 cm
Connector
USB Type A - male (input)
Connector (Second End)
HDMI - female (output)
USB 2.0/ USB 3.0
USB power + audio
P/N: HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50
Cable Type
Video interface converter - USB power + audio
Interface Supported
HDMI / USB
Jacket Material
Plastic
USB 2.0/ USB 3.0
Length
20 cm
Multi-channel audio
Adapters & Converters
3840 x 2160
Refresh Rate
30 Hz
Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Apple MacOS X 10.6 - 10.12, Google Chrome OS 55 or later, Apple macOS 10.14, Apple macOS 10.15
Connector
9 pin USB Type A - male (input)
19 pin HDMI Type A - female (output)
WHQL, FCC, RoHS, WEEE, REACH, DisplayLink Plug and Display, RCM
TAA Compliant
4.5 cm
1.5 cm
65 g
Shipping Width
14.5 cm
Shipping Depth
21.2 cm
Shipping Height
4.1 cm
Shipping Weight
198 g
9X8Z StarTech.com USB 3.0 to HDMI and DVI Dual Monitor External Video Card Adapter In Stock £73.33
9X8Z StarTech.com USB 3 to HDMI w/ USB Hub In Stock £49.54
9X8Z StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p In Stock £45.72
9X8Z StarTech.com USB 3.0 to HDMI External Multi Monitor Video Graphics Adapter for Mac & PC In Stock £53.49
9X8Z StarTech.com USB 3.0 to 4K HDMI External Multi Monitor Video Graphics Adapter In Stock £69.51
9X8Z StarTech.com USB 3.0 to Dual HDMI Adapter In Stock £57.28
Price Range Ex VAT: 50 - 100
