Product
StarTech.com USB 3.0 to 4-Bay SATA 6Gbps Hard Drive Docking Station w/ UASP & Dual Fans
Quicklinx: 9PS8WS00 Mfr#: SDOCK4U33
Hurry, only 1 left in stock!
£143.46 ex VAT
£172.15 inc VAT
Connect and swap four 2.5/3.5" SATA III (6 Gbps) drives through USB 3.0 with UASP. The SDOCK4U33 four-bay 2.5/3.5" SATA HDD / SSD docking station lets you dock and swap four drives from your desktop or laptop computer simultaneously, using a single USB port.
Get the most out of your SATA III (Gbps) solid state drives and hybrid drives with this UASP (USB Attached SCSI Protocol) enhanced hard drive docking station. With performance up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller, UASP ensures high performance by reducing bottleneck.
The hard drive dock features independently-powered SATA connectors for each individual drive, ensuring you can operate drives separately. This gives you the freedom to hot-swap one drive while transferring data to another, saving you time. Plus, the built-in fans keep your drives running cool, ensuring optimal performance and helps to prevent premature drive failure.
Extend the value of this hard drive docking station further with the addition of the SATA to IDE Hard Drive Adapter (SAT2IDEADP), allowing easy insertion of any 2.5 or 3.5in. IDE hard drive into a SATA hard drive dock.
To ensure compatibility with your computer system, the SDOCK4U33 supports all of the leading operating systems, including: Microsoft Windows (8/7/Vista/XP/Server 2008/Server 2003), Apple OSX (10.9/10.8/10.7/10.6), Linux, and Google Chrome OS.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP-enabled StarTech.com Enclosure, and a SATA III solid state drive.
StarTech.com USB 3.0 to 4-Bay SATA 6Gbps Hard Drive Docking Station w/ UASP & Dual Fans - 2.5/3.5in SSD / HDD Dock - storage enclosure
Storage enclosure
0 (installed) / 4 (max)
Supported Drives
SATA-600
Linux, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Google Chrome OS, Apple MacOS X 10.7 Lion, Apple MacOS X 10.8, Apple MacOS X 10.9, Microsoft Windows XP / 7 / 8 / 8.1 (32/64 bits)
AC 120/230 V
17.12 cm x 29.05 cm x 8.73 cm
1.028 kg
2 years warranty
Storage enclosure
Enclosure Colour
Chassis
0
Supported Devices / Modules Qty
4
Supported Drives
SATA-600
Expansion Bays
4 (total) / 4 (free) x external - 2.5" / 3.5" shared
1 x USB 3.0 - 9 pin USB Type B , 4 x SATA 6Gb/s - 22 pin Serial ATA
1 x USB cable
FCC, RoHS
External power adapter
AC 120/230 V
17.12 cm
29.05 cm
8.73 cm
1.028 kg
5 °C
35 °C
20 - 80%
9PS8 StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.90
9PS8 StarTech.com 3.5in Silicone Hard Drive Protector Sleeve with Connector Cap In Stock £5.29
9PS8 StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £24.29
9PS8 StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £10.57
9PS8 StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP In Stock £30.85
9PS8 StarTech.com 2 Port SuperSpeed Mini PCI Express USB 3.0 Adapter Card w/ Bracket Kit and UASP Support In Stock £38.34
Price Range Ex VAT: 100 - 150
