Clone a 2.5in/3.5in SATA drive without a host computer connection, or dock the drives over USB 3.0 for easy access. The SATDOCK2REU3 USB 3.0 Standalone Duplicator and Eraser Dock lets you connect your 2.5in/3.5in SATA HDDs or SSDs through SuperSpeed USB 3.0, with the ability to swap drives in and out as needed. The dock also functions as a standalone drive duplicator and eraser - an efficient and versatile solution for external drive management.
Featuring standalone Sector by Sector hard drive duplication with built-in LED progress bar, and support for 2 drive single pass over writing the SATDOCK22EU3 is a user-friendly all-in-one solution for any application requiring hard drive duplication or erasing.
With support for SATA I/II/III, and large capacity drives (tested up to 4TB) this HDD/SSD docking station is compatible with virtually any SATA hard drive, and greatly increases the storage/backup capabilities of your computer.
Extend the value of this hard drive docking station further with the addition of the SATA to IDE Hard Drive Adapter (SAT2IDEADP), allowing easy insertion of any 2.5 or 3.5in IDE hard drive into a SATA hard drive dock.
- StarTech.com Dual Bay Hard Drive Duplicator and Eraser, Standalone HDDSSD ClonerCopier, USB 3.0 to SATA Docking Station, Hard Disk Duplicator and Sanitizer Dock - ToollessTop-Loading Design - hard drive duplicator
- Hard drive duplicator
- Installed Devices / Modules Qty
- 0 (installed) / 2 (max)
- Supported Drives
- SATA-300
- Storage Controller
- SATA (SATA 3Gb/s)
- Hard Drive
- No HDD
- OS Required
- Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
- Power
- AC 120/230 V
- 10.3 cm x 12.8 cm x 6.2 cm
- 424 g
- 2-year warranty
- Designed For
- P/N: SVA12M5NA
Chassis
- 0
- Supported Devices / Modules Qty
- 2
- Supported Drives
- SATA-300
Storage Controller
- SATA - integrated (USB 3.0)
- Interface Type
- SATA 3Gb/s
- Max Storage Devices Qty
- 2
Hard Drive
- No HDD
- Expansion Bays
- External - 2.5" , External - 3.5"
- 1 x USB 3.0 - 9 pin USB Type B , 2 x SATA 3Gb/s - 22 pin Serial ATA
- OS Required
- Tested with up to 4TB 7200 RPM 3.5" hard drives, tested with up to 1TB 7200 RPM 2.5" hard drives
- Cables Included
- 1 x USB cable
- FCC, RoHS
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 10.3 cm
- 12.8 cm
- 6.2 cm
- 424 g
- Limited warranty - 2 years
- 0 °C
- 85 °C
- 5 - 90%
- Designed For
- P/N: SVA12M5NA
