StarTech.com USB 3.0 Multi Media Flash Memory Card Reader with 2-Port USB 3.0 Hub
Quicklinx: B0N1WS00 Mfr#: FCREADU3HC
Add a compact external memory card reader to your computer through USB, and charge or connect USB devices with the built-in USB fast charge hub. The FCREADU3HC USB 3.0 card reader lets you quickly mount all major media card types onto your desktop or laptop computer through a USB 3.0 port. The card reader supports the most common mass storage device formats, including CompactFlash, SecureDigital and MemoryStick cards, making it the perfect high-bandwidth solution for your photography and videography workstation.
Plus, the card reader is backward compatible with USB 2.0 and USB 1.1 computer systems, making it a great addition to any USB-enabled computer.
Plus, the card reader lets you keep your tablets and smartphones charged and ready to go, and saves you time with an integrated USB 2.0 fast charging port that charges your mobile devices such as Apple iPad & iPhone and Android devices, as quickly as if you were connected to a wall outlet. This fast charge port has been specially designed for compatibility with a wide range of tablets and smartphones.
The card reader also lets you connect additional USB 3.0 devices to your computer through the same high-speed USB host connection, with a built-in 2-port USB 3.0 hub.
StarTech.com USB 3.0 Multi Media Flash Memory Card Reader with 2-Port USB 3.0 Hub & USB Fast Charge Port - card reader - USB 3.0
Card reader - external
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, miniSD, RS-MMC, TransFlash, microSD, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, SDXC Memory Card, Memory Stick XC
Host Interface
USB 3.0
Built-in USB hub, MagicGate support
P/N: SVA5M4NEUA
Host Interface
USB 3.0
111 mm
60 mm
26 mm
100 g
Memory Card
(max)
Additional Ports
1 x USB 3.0 , 2 x USB 3.0 , 1 x USB charge port
Required Ports
1 x 9 pin USB Type A
Linux, Microsoft Windows 2000, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Google Chrome OS, Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks
USB cable, power adapter
FCC, RoHS
P/N: SVA5M4NEUA
