Add the Ability to Use Multiple Types of Flash Memory Cards, Including CompactFlash?, SecureDigital? and MemoryStick? Cards. The FCREADHCU3 USB 3.0 Card Reader enables easy read/write access to a variety of popular flash memory card formats/types (CompactFlash?, Secure Digital?, Memory Stick?) in a single unit, over a high speed USB 3.0 connection. Using a connection over USB 3.0, which is up to 10 times faster than the USB 2.0 standard, makes transferring large data files much quicker; it (USB 3.0) is still backward compatible with USB 2.0 however, ensuring compatibility with older systems. This compact and lightweight external card reader offers a portable, convenient solution for accessing many different types of Flash Memory/Media cards and is easy to use, with no driver or software installation required.
- StarTech.com USB 3.0 Multi Media Flash Memory Card Reader - Card reader (Multi-Format) - USB 3.0 - FCREADHCU3 - card reader - USB 3.0
- Product Type
- Card reader - external
- Supported Memory Cards
- CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, miniSD, RS-MMC, microSD, SDHC Memory Card, miniSDHC, microSDHC, Memory Stick PRO-HG Duo, SDXC Memory Card, microSDXC
- Host Interface
- USB 3.0
- Black
- Power indicator
- 2-year warranty
- Product Type
- Host Interface
- USB 3.0
- Black
- Power indicator
- 5.9 cm
- 8.6 cm
- 2.1 cm
- 69 g
Memory Card
- Capacity
- (max)
- Required Ports
- 1 x 9 pin USB Type B
- OS Required
- Apple MacOS X 10.4, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
- FCC, RoHS
- Limited warranty - 2 years
StarTech.com 10 ft SuperSpeed USB 3.0 Cable A to B - M/M | In Stock | £7.60 |
StarTech.com 3 ft SuperSpeed USB 3.0 Cable A to B - M/M | In Stock | £2.92 |
StarTech.com 6 ft SuperSpeed USB 3.0 Cable A to B - M/M | In Stock | £4.88 |
StarTech.com 3 ft Black SuperSpeed USB 3.0 Cable A to B - M/M | In Stock | £4.79 |
StarTech.com 1 ft SuperSpeed USB 3.0 Cable A to B - M/M | In Stock | £5.12 |
StarTech.com USB 3.0 Multi Media Flash Memory Card Reader | In Stock | £20.36 |
