Add a compact external memory card reader to any computer with a USB 3.0 port. The FCREADMICRO3 USB 3.0 Multi-media Card Reader offers quick access to the most popular flash card formats, from any computer with a USB port (optimal performance with 3.0, backward compatible with USB 2.0).
Suitable for quickly accessing memory cards of virtually any portable media device (e.g. digital cameras, MP3 players, etc.), this versatile media card reader supports the most popular card types, including: Secure Digital (SD), Multi-Media Card (MMC), Mini-SD, Micro-SD/SDHC (T-flash), SDHC, SDXC, RS-MMC, Mobile-MMC and MMC-micro, Memory Stick (MS), Memory Stick PRO (MS-PRO), MS Duo, MS-PRO Duo, Memory Stick XC, Micro-MS (M2), MSPRO-HG Duo 8-bit mode.
An ideal Laptop or Desktop accessory, this pocket-sized memory card reader is lightweight, portable.
- StarTech.com USB 3.0 Multimedia Memory Card Reader - Portable SDHC MicroSD Card Reader - External USB Flash Card Reader (FCREADMICRO3) - card reader - USB 3.0
- Product Type
- Card reader - external
- Supported Memory Cards
- Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, miniSD, RS-MMC, MultiMediaCardmobile, microSD, MultiMediaCardmicro, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, Memory Stick PRO-HG Duo, SDXC Memory Card, Memory Stick XC
- Host Interface
- USB 3.0
- Black
- 2-year warranty
- Product Type
- Host Interface
- USB 3.0
- Black
- 2.3 cm
- 7.2 cm
- 1.5 cm
- 15 g
Memory Card
- Capacity
- (max)
- Required Ports
- 1 x 9 pin USB Type B
- OS Required
- Microsoft Windows 2000, Apple MacOS X, Microsoft Windows Server 2008 R2, Linux 2.4.x or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
- FCC, RoHS
- Limited warranty - 2 years
