StarTech.com USB 3.0/eSATA Dual 3.5" SATA III Hard Drive External RAID Enclosure w/ UASP - Black
Quicklinx: 95QMWS00 Mfr#: S3520BU33ER
Stock Status: Clearance
Hurry, only 3 left in stock!
£62.49 ex VAT
£74.98 inc VAT
The S3520BU33ER 2-Bay RAID enclosure offers a high-performance external storage solution, enabling you to build a secure RAID array with two 3.5" SATA hard drives, with the option to connect it to your computer through either an available USB 3.0 or eSATA port.
For fast data transfers and efficient performance from your SATA III drives, the RAID enclosure supports full SATA III transfer speeds, as well as full USB 3.0 transfer speeds. When connected through USB, the enclosure supports UASP, which offers performance up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller.
With support for JBOD, Spanning, RAID 0, and RAID 1, the enclosure offers several options that enable you to customize your drive arrangement based on your storage requirements. To maximize both durability and reliability, the external RAID enclosure features high-quality aluminum construction with a built-in fan that helps improve ventilation and maintain a better operating environment for your drives.
StarTech.com USB 3 eSATA Dual 3.5" SATA III HDD RAID Enclosure UASP - hard drive array
Hard drive array
Max Supported Capacity
4 TB
USB 3.0, SATA 6Gb/s
0 (installed) / 2 (max)
Supported Drives
SATA-600
Storage Controller
RAID (SATA 6Gb/s) - RAID 0, 1, JBOD, BIG
Hard Drive
No HDD
Apple MacOS, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Linux 2.6.31 or later, Windows 8 (32/64 bits)
AC 120/230 V - 50 - 60 Hz
11.55 cm x 18.05 cm x 8.5 cm
980 g
P/N: DK30BACDD, DK30CHDDPPD, DK30CHDPPDUE, PEXUSB3S24, PEXUSB3S2EI, PEXUSB3S42, PEXUSB3S7, SVA12M5NA, USB3SDOCKDD, USB3VDOCKD
Hard drive array
Enclosure Colour
Chassis
0
Supported Devices / Modules Qty
2
Supported Drives
SATA-600
Storage
4 TB
HDD Array External Interface
USB 3.0, SATA 6Gb/s
Storage Controller
RAID - integrated (SATA 6Gb/s)
Interface Type
SATA 6Gb/s
Data Transfer Rate
6 GBps
Max Storage Devices Qty
2
RAID Level
RAID 0, RAID 1, JBOD, BIG
Hard Drive
No HDD
Expansion Bays
2 (total) / 2 (free) x internal - 3.5" x 1/3H
1 x eSATA - 7 pin external Serial ATA , 1 x USB 3.0 - 9 pin USB Type A
1 x eSATA cable , 1 x USB cable
Software Included
Drivers & Utilities
UL, FCC, RoHS
External power adapter
11.55 cm
18.05 cm
8.5 cm
980 g
5 °C
35 °C
20 - 80%
95QM StarTech.com 6 ft Shielded External eSATA Cable M/M In Stock £9.34
95QM StarTech.com 2 Port SATA 6 Gbps PCI Express eSATA Controller Card In Stock £22.16
95QM StarTech.com 2 Port PCI Express SATA 6 Gbps eSATA Controller Card - 2 Int/2 Ext In Stock £27.46
95QM StarTech.com 1 Port SATA to eSATA Slot Plate Bracket In Stock £5.04
95QM StarTech.com USB 3.0/eSATA Dual 3.5" SATA III Hard Drive External RAID Enclosure w/ UASP - Black In Stock £62.49
Price Range Ex VAT: 50 - 100
