The S3520BU33ER 2-Bay RAID enclosure offers a high-performance external storage solution, enabling you to build a secure RAID array with two 3.5" SATA hard drives, with the option to connect it to your computer through either an available USB 3.0 or eSATA port.
For fast data transfers and efficient performance from your SATA III drives, the RAID enclosure supports full SATA III transfer speeds, as well as full USB 3.0 transfer speeds. When connected through USB, the enclosure supports UASP, which offers performance up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller.
With support for JBOD, Spanning, RAID 0, and RAID 1, the enclosure offers several options that enable you to customize your drive arrangement based on your storage requirements. To maximize both durability and reliability, the external RAID enclosure features high-quality aluminum construction with a built-in fan that helps improve ventilation and maintain a better operating environment for your drives.
- StarTech.com USB 3 eSATA Dual 3.5" SATA III HDD RAID Enclosure UASP - hard drive array
- Hard drive array
- Black
- Max Supported Capacity
- 4 TB
- Interface
- USB 3.0, SATA 6Gb/s
- Installed Devices / Modules Qty
- 0 (installed) / 2 (max)
- Supported Drives
- SATA-600
- Storage Controller
- RAID (SATA 6Gb/s) - RAID 0, 1, JBOD, BIG
- Hard Drive
- No HDD
- OS Required
- Apple MacOS, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Linux 2.6.31 or later, Windows 8 (32/64 bits)
- Power
- AC 120/230 V - 50 - 60 Hz
- 11.55 cm x 18.05 cm x 8.5 cm
- 980 g
- 2-year warranty
- Designed For
- P/N: DK30BACDD, DK30CHDDPPD, DK30CHDPPDUE, PEXUSB3S24, PEXUSB3S2EI, PEXUSB3S42, PEXUSB3S7, SVA12M5NA, USB3SDOCKDD, USB3VDOCKD
- Hard drive array
- Enclosure Colour
- Black
Chassis
- 0
- Supported Devices / Modules Qty
- 2
- Supported Drives
- SATA-600
Storage
- 4 TB
- HDD Array External Interface
Storage Controller
- RAID - integrated (SATA 6Gb/s)
- Interface Type
- SATA 6Gb/s
- Data Transfer Rate
- 6 GBps
- Max Storage Devices Qty
- 2
- RAID Level
- RAID 0, RAID 1, JBOD, BIG
Hard Drive
- No HDD
- Expansion Bays
- 2 (total) / 2 (free) x internal - 3.5" x 1/3H
- 1 x eSATA - 7 pin external Serial ATA , 1 x USB 3.0 - 9 pin USB Type A
- OS Required
- Cables Included
- 1 x eSATA cable , 1 x USB cable
- Software Included
- Drivers & Utilities
- UL, FCC, RoHS
- Power Device
- External power adapter
- Voltage Required
- 11.55 cm
- 18.05 cm
- 8.5 cm
- 980 g
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 20 - 80%
- Designed For
StarTech.com 6 ft Shielded External eSATA Cable M/M | In Stock | £9.32 |
StarTech.com 2 Port SATA 6 Gbps PCI Express eSATA Controller Card | In Stock | £22.16 |
StarTech.com 2 Port PCI Express SATA 6 Gbps eSATA Controller Card - 2 Int/2 Ext | In Stock | £27.46 |
StarTech.com 1 Port SATA to eSATA Slot Plate Bracket | In Stock | £5.04 |
