StarTech.com USB 3.0 & eSATA HDD Dock
Quicklinx: B684WS00 Mfr#: SDOCKU33EF
Type: Storage controller
HD Size: 2.5, 3.5
Power Supply: Power adapter
Hurry, only 1 left in stock!
£52.49 ex VAT
£62.98 inc VAT
Easily connect and swap hard drives and solid-state drives to and from your computer system, with the added benefit of a built-in cooling fan. This USB 3.0 and eSATA docking station makes it easy for you to connect and swap your 2.5in or 3.5inSATAhard drives (HDD) and solid-state drives (SSD).The docking station also has a built-in fan that keeps your drives running at an optimal temperature for peak performance and longer drive lifespan.
With support for either USB 3.0 or eSATA host connections, this versatile drive dock gives you the freedom to connect to your computer through either port. Because USB is available on virtually any computer, you can rest assured that this docking station will work with your desktop or laptop. Plus, the added benefit of eSATA ensures you can achieve SATA 6 Gpbs performance on computers with an available eSATA port.
To ensure all your drives are supported, the docking station features a sleek slot-loading design that supports both 2.5in and 3.5in drives. The docking station has also been rigorously tested for support with large capacity drives (tested up to 6TB).
For optimal performance, the docking station has a built-in 80mm fan that helps keep your drives running cooler. The fan offers variable speed control which enables you to make adjustments on the fly, in order to reduce power consumption and noise when your drives aren't being accessed. The HDD dock will also power down your SATA drives after a period of inactivity (USB mode only) or when the computer is turned off, to help reduce power consumption and noise when not being accessed.
To save you time, this docking station is loaded with high-performance features on both interface connections.
For the fastest possible performance, this dock supports full SATA III bandwidth of 6 Gbps when connected through eSATA, ensuring you can get the most out of your solid-state drives.
With USB 3.0 the dock ensures high-bandwidth transfer speeds up to 5 Gbps. The USB host interface connection also supports UASP, which delivers performance up to 70% faster than conventional USB 3.0 when paired with a compatible host controller. UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
StarTech.com Hot-Swap Hard Drive Docking Station for 2.5"/3.5" SATA III Hard Drives - External eSATA/USB 3.0 Hard Drive Dock w/ UASP (SDOCKU33EF) - storage controller - SATA 6Gb/s - eSATA 6Gb/s, USB 3.0
Storage controller - external
Bus Type
Expansion Bays
1 x hot-swap - 2.5" / 3.5" shared
Hard Drive Form Factor Compatibility
2.5", 3.5"
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive
AC 120/230 V
Windows 8, Apple MacOS X 10.8 or later
9.5 cm x 12.6 cm x 13.4 cm
477 g
P/N: SVA12M2NEUA, SVA12M5NA
2.5", 3.5"
Host Bus
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive
Bays
1 x SATA 6Gb/s - SATA combo
1 x USB 3.0 - 9 pin USB Type B , 1 x eSATA 6Gb/s - 7 pin Serial ATA
1 x USB 3.0 cable - external - 1 m , 1 x eSATA cable - external - 1 m
LED indicator, tested with up to 6TB 7200 RPM hard drives
FCC, RoHS
Power adapter
AC 120/230 V
9.5 cm
12.6 cm
13.4 cm
477 g
5 °C
80 °C
8 - 90%
B684 StarTech.com 6 ft Shielded External eSATA Cable M/M In Stock £10.50
B684 StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.36
B684 StarTech.com 1ft Low Profile SATA to eSATA Plate Adapter In Stock £6.36
B684 StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £20.67
B684 StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £12.60
B684 StarTech.com 1m USB 3 Cable Right Angle BK In Stock £6.63
B684 StarTech.com 2m (6 ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £11.11
B684 StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £8.86
B684 StarTech.com USB 3.0 SATA Hard Drive Docking Station SSD / HDD with integrated Fast Charge USB Hub In Stock £48.65
B684 StarTech.com USB 3.0 / eSATA Dual Hard Drive Docking Station with UASP for 2.5/3.5in SATA SSD / HDD In Stock £62.45
B684 StarTech.com 18in 1 Port SATA to eSATA Plate Adapter In Stock £8.04
B684 StarTech.com DC Power Adapter - 12V, 2A In Stock £12.66
B684 StarTech.com DC Power Adapter - 12V, 5A In Stock £41.16
HD Size: 2.5
HD Size: 3.5
