Easily connect and swap hard drives and solid-state drives to and from your computer system, with the added benefit of a built-in cooling fan. This USB 3.0 and eSATA docking station makes it easy for you to connect and swap your 2.5in or 3.5inSATAhard drives (HDD) and solid-state drives (SSD).The docking station also has a built-in fan that keeps your drives running at an optimal temperature for peak performance and longer drive lifespan.
With support for either USB 3.0 or eSATA host connections, this versatile drive dock gives you the freedom to connect to your computer through either port. Because USB is available on virtually any computer, you can rest assured that this docking station will work with your desktop or laptop. Plus, the added benefit of eSATA ensures you can achieve SATA 6 Gpbs performance on computers with an available eSATA port.
To ensure all your drives are supported, the docking station features a sleek slot-loading design that supports both 2.5in and 3.5in drives. The docking station has also been rigorously tested for support with large capacity drives (tested up to 6TB).
For optimal performance, the docking station has a built-in 80mm fan that helps keep your drives running cooler. The fan offers variable speed control which enables you to make adjustments on the fly, in order to reduce power consumption and noise when your drives aren't being accessed. The HDD dock will also power down your SATA drives after a period of inactivity (USB mode only) or when the computer is turned off, to help reduce power consumption and noise when not being accessed.
To save you time, this docking station is loaded with high-performance features on both interface connections.
For the fastest possible performance, this dock supports full SATA III bandwidth of 6 Gbps when connected through eSATA, ensuring you can get the most out of your solid-state drives.
With USB 3.0 the dock ensures high-bandwidth transfer speeds up to 5 Gbps. The USB host interface connection also supports UASP, which delivers performance up to 70% faster than conventional USB 3.0 when paired with a compatible host controller. UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
- StarTech.com Hot-Swap Hard Drive Docking Station for 2.5"/3.5" SATA III Hard Drives - External eSATA/USB 3.0 Hard Drive Dock w/ UASP (SDOCKU33EF) - storage controller - SATA 6Gb/s - eSATA 6Gb/s, USB 3.0
- Storage controller - external
- Bus Type
- Black
- Expansion Bays
- 1 x hot-swap - 2.5" / 3.5" shared
- Hard Drive Form Factor Compatibility
- 2.5", 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive
- Power
- AC 120/230 V
- System Requirements
- Windows 8, Apple MacOS X 10.8 or later
- 9.5 cm x 12.6 cm x 13.4 cm
- 477 g
- 2-year warranty
- Designed For
- P/N: SVA12M2NEUA, SVA12M5NA
- 2.5", 3.5"
- Host Bus
- Black
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- Hard drive
- Bays
- 1 x SATA 6Gb/s - SATA combo
- Connections
- 1 x USB 3.0 - 9 pin USB Type B , 1 x eSATA 6Gb/s - 7 pin Serial ATA
- Cables Included
- 1 x USB 3.0 cable - external - 1 m , 1 x eSATA cable - external - 1 m
- LED indicator, tested with up to 6TB 7200 RPM hard drives
- FCC, RoHS
- Power adapter
- Voltage Required
- AC 120/230 V
- OS Required
- Limited warranty - 2 years
- 9.5 cm
- 12.6 cm
- 13.4 cm
- 477 g
- 5 °C
- 80 °C
- 8 - 90%
- Designed For
StarTech.com 3 ft Shielded External eSATA Cable M/M | In Stock | £8.88 |
StarTech.com 6 ft Shielded External eSATA Cable M/M | In Stock | £10.50 |
StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap | In Stock | £3.36 |
StarTech.com 1ft Low Profile SATA to eSATA Plate Adapter | In Stock | £6.36 |
StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks | In Stock | £20.67 |
StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) | In Stock | £12.60 |
StarTech.com 1m USB 3 Cable Right Angle BK | In Stock | £6.63 |
StarTech.com 2m (6 ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £11.11 |
StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £8.86 |
StarTech.com USB 3.0 SATA Hard Drive Docking Station SSD / HDD with integrated Fast Charge USB Hub | In Stock | £48.65 |
StarTech.com 18in 1 Port SATA to eSATA Plate Adapter | In Stock | £8.04 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £12.66 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.16 |
