StarTech.com USB 3.0 / eSATA 5-Bay Hot-Swap 2.5/3.5" SATA III Hard Drive Enclosure with UASP
Quicklinx: 9TV8WS00 Mfr#: S355BU33ERM
Connect five hot-swappable 2.5/3.5" SATA III hard drives to your computer externally through USB 3.0 with UASP or eSATA. The S355BU33ERM 5-bay Removable Hard Drive Enclosure lets you access five individual 2.5" or 3.5" hard drives simultaneously, through a single eSATA or USB port connection to your laptop or desktop computer.
For fast performance and efficient data transfers, you can connect the removable drive enclosure to your computer through either eSATA or USB 3.0. The enclosure supports full SATA III data transfer rates up to 6 Gbps, when connected through eSATA. When connected through USB 3.0, the enclosure supports transfer speeds up 5 Gbps plus support for UASP, which performs up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller.
With support for the fastest drive technologies available including SATA III (6 Gbps), hybrid drives and solid state drives (SSD), the enclosure helps you save time through optimized performance from your external storage.
For optimal drive performance and longevity, the HDD/SSD enclosure features both a built-in fan as well as solid aluminum drive trays, which help cool your drives while ensuring maximum heat dissipation.
To ensure compatibility with your computer system, the S355BU33ERM supports all of the leading operating systems, including: Microsoft Windows (8/7/Vista/XP/Server 2008/Server 2003), Apple OSX (10.9/10.8/10.7/10.6), Linux, and Google Chrome OS.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP-enabled StarTech.com Enclosure, and a SATA III solid state drive.
StarTech.com USB 3.0/eSATA 5-Bay Hot-Swap 2.5/3.5" SATA HDD Case w/ UASP - storage enclosure
Storage enclosure
0 (installed) / 5 (max)
Supported Drives
SATA-600
Storage Controller
(eSATA-600)
AC 120/230 V
15 cm x 28.2 cm x 21.5 cm
4.1 kg
Storage enclosure
Enclosure Colour
Chassis
0
Supported Devices / Modules Qty
5
Supported Drives
SATA-600
CPU
No CPU
Storage Controller
(USB 3.0)
Interface Type
eSATA-600
Expansion Bays
5 (total) / 5 (free) x hot-swap - 2.5" / 3.5" shared
5 x eSATA 6Gb/s
1 x eSATA cable , 1 x USB 3.0 cable , 1 x power cable
FCC, RoHS
eSATA bracket
Internal power supply
AC 120/230 V
15 cm
28.2 cm
21.5 cm
4.1 kg
5 °C
55 °C
10 - 90% (non-condensing)
9TV8 StarTech.com 2 Port PCI Express SATA 6 Gbps eSATA Controller Card - 2 Int/2 Ext In Stock £30.82
9TV8 StarTech.com 1m USB 3 Cable Right Angle BK In Stock £6.63
9TV8 StarTech.com 5 ft Black Desktop SuperSpeed USB 3.0 Extension Cable - A to A M/F In Stock £11.54
9TV8 StarTech.com USB 3.0 / eSATA Dual-Bay Trayless 3.5" SATA III Hard Drive Enclosure with UASP In Stock £112.36
