StarTech.com USB 3.0 / eSATA 4-Bay 3.5in SATA III Hard Drive Enclosure w/ built-in HDD Fan & UASP
Quicklinx: 9PRWWS00 Mfr#: S3540BU33E
Hurry, only 1 left in stock!
£147.75 ex VAT
£177.30 inc VAT
Add four 3.5" SATA III hard drives to your computer externally through USB 3.0 with UASP or eSATA. The S3540BU33E 4-Bay HDD enclosure lets you install four 3.5" SATA hard drives into an external enclosure, and connect to your computer through USB 3.0 or eSATA.
For fast performance and efficient data transfers, the enclosure supports SATA III transfer speeds - up to 6 Gbps when connected through eSATA. The versatile enclosure can also be connected through USB 3.0, with support for UASP, performing up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller.
To ensure compatibility with your computer system, the S3540BU33E supports all of the leading operating systems. UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance. At the same peak in testing UASP also shows an 80% reduction in required processor resources.
StarTech.com USB 3.0 / eSATA 4-Bay 3.5in SATA HDD Enclosure w/ Fan & UASP - storage enclosure
Storage enclosure
0 (installed) / 4 (max)
Supported Drives
SATA-600
Storage Controller
(eSATA-600)
Linux, Microsoft Windows 2000, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Google Chrome OS, Apple MacOS X 10.7 Lion, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks
AC 120/230 V
11.6 cm x 20.1 cm x 14.6 cm
1.6 kg
Storage enclosure
Enclosure Colour
Chassis
0
Supported Devices / Modules Qty
4
Supported Drives
SATA-600
Storage Controller
(USB 3.0)
Interface Type
eSATA-600
Expansion Bays
4 (total) / 4 (free) x hot-swap - 3.5"
4 x eSATA 6Gb/s
LED indicator, tested with up to 6TB 7200 RPM hard drives
1 x eSATA cable , 1 x USB 3.0 cable
FCC, RoHS
External power adapter
AC 120/230 V
11.6 cm
20.1 cm
14.6 cm
1.6 kg
5 °C
35 °C
20 - 80%
9PRW StarTech.com 3 ft Shielded External eSATA Cable M/M In Stock £6.82
9PRW StarTech.com 6 ft Shielded External eSATA Cable M/M In Stock £9.22
9PRW StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £23.84
9PRW StarTech.com 2 Port Flush Mount ExpressCard 54mm SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £29.85
Price Range Ex VAT: 100 - 150
