Brand
StarTech.com USB 2.0 to SATA/IDE Combo Adapter for 2.5/3.5" SSD/HDD
Quicklinx: 7Y43WS00 Mfr#: USB2SATAIDE
15 in stock
£23.36 ex VAT
£28.03 inc VAT
Quickly and easily connect SATA and/or IDE hard drives through USB 2.0. This USB 2.0 to IDE/SATA Adapter Cable connects any standard 2.5in or 3.5in SATA or IDE hard drive to a computer through USB 2.0. The adapter lets you connect a bare drive with no enclosure, saving time and hassle.
The USB 2.0 SATA/IDE Adapter features LED indicators that allow you to easily monitor status and activity updates, and is designed for durability and reliability.
StarTech.com USB 2.0 to IDE SATA Adapter - 2.5 / 3.5" SSD / HDD - USB to IDE & SATA Converter Cable - USB Hard Drive Adapter (USB2SATAIDE) - storage controller - ATA / eSATA - USB 2.0
Storage controller - external
Bus Type
USB 2.0
ATA / eSATA
Supported Devices
Hard drive
Microsoft Windows 98 Second Edition, Microsoft Windows 2000, Apple MacOS 8.6 or later, Microsoft Windows Millennium Edition, Microsoft Windows XP, Microsoft Windows Vista
4.3 cm x 87 cm x 1.5 cm
51 g
Host Bus
USB 2.0
Storage Controller
ATA / eSATA
Supported Devices
Hard drive
1 x ATA - 40 PIN IDC , 1 x ATA - 44 PIN IDC , 1 x SATA 1.5Gb/s - eSATA
1 x USB 2.0 - 4 pin USB Type A
FCC
Power adapter
4.3 cm
87 cm
1.5 cm
51 g
7Y43 StarTech.com 24" Serial ATA Cable In Stock £3.89
7Y43 StarTech.com 18in SATA Serial ATA Cable In Stock £3.64
7Y43 StarTech.com 18in Dual Drive Ultra ATA IDE Hard Drive Cable In Stock £5.40
7Y43 StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable In Stock £3.98
7Y43 StarTech.com 12in Latching SATA Cable In Stock £3.67
7Y43 StarTech.com 18in Latching SATA Cable In Stock £4.36
7Y43 StarTech.com 40 Pin Female IDE to SATA Adapter Converter In Stock £10.91
7Y43 StarTech.com 12in Latching SATA to Right Angle SATA Serial ATA Cable In Stock £3.76
7Y43 StarTech.com 6in SATA Serial ATA Cable In Stock £3.35
7Y43 StarTech.com 12in SATA Serial ATA Cable In Stock £3.34
7Y43 StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F In Stock £4.56
7Y43 StarTech.com 6in Latching SATA Cable In Stock £3.68
7Y43 StarTech.com 8in Latching SATA to SATA Cable - F/F In Stock £3.79
7Y43 StarTech.com 12in SATA to Left Angle SATA Serial ATA Cable In Stock £3.95
7Y43 StarTech.com 6in SATA to Left Angle SATA Serial ATA Cable In Stock £3.65
7Y43 StarTech.com 6in SATA to Right Angle SATA Serial ATA Cable In Stock £3.61
7Y43 StarTech.com USB 2.0 to SATA/IDE Combo Adapter for 2.5/3.5" SSD/HDD In Stock £23.36
7Y43 StarTech.com 36in SATA to Right Angle SATA Serial ATA Cable In Stock £4.68
7Y43 StarTech.com 18in SATA to Left Side Angle SATA Serial ATA Cable In Stock £3.08
7Y43 StarTech.com USB 3.0 to SATA or IDE Hard Drive Adapter Converter In Stock £37.10
7Y43 StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable In Stock £10.21
7Y43 StarTech.com USB 3.1 Gen 2 Adapter Cable In Stock £15.82
7Y43 StarTech.com USB 3.1 Adapter Cable w/ USB-C In Stock £20.33
7Y43 StarTech.com USB C to SATA Adapter Cable In Stock £40.42
Stock Status: In stock
