Your basket is empty
StarTech.com USB 2.0 to Gigabit Ethernet NIC Network Adapter
Quicklinx: 82HYWS00 Mfr#: USB21000S2
  • Windows 8 (32/64 bits)
Add Gigabit Ethernet to any USB 2.0 compatible PC or Laptop computer. The USB21000S2 USB 2.0 to Gigabit Ethernet Adapter offers a reliable USB Ethernet connection, adding a single RJ45 Ethernet port to a USB-enabled computer system, with support for connecting to Gigabit networks.
Backward compatible with older USB 1.x computer systems, this compact and portable USB Gigabit network adapter offers an ideal desktop replacement network adapter or laptop accessory. With support for features such as Jumbo Frames, VLAN tagging and Wake on LAN (WOL), the adapter is suitable for home and business users alike.
StarTech.com USB 2.0 to Gigabit Ethernet NIC Network Adapter - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
Ports
Gigabit Ethernet
3.5 cm 2 cm
Length
27.5 cm
40.5 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, USB 1.1, USB 2.0
Linux, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7 Lion, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Windows 10 (32/64 bits)
2 years warranty
Network adapter
External
USB 2.0
Ports
Gigabit Ethernet
Wired
Cabling Type
Status Indicators
Link/activity
USB powered
1 x 1000Base-T - RJ-45
1 x USB 2.0 - 4 pin USB Type A
3.5 cm
2 cm
Length
27.5 cm
40.5 g
70 °C
5 - 95%
82HY StarTech.com 3 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £2.61
82HY StarTech.com 15 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £3.80
82HY StarTech.com 16 ft USB 2.0 Active Extension Cable - M/F In Stock £13.61
82HY StarTech.com 10ft USB Extension Cable A-A In Stock £3.75
82HY StarTech.com 5ft Desktop USB Extension Cable - A Male to A Female In Stock £4.38
82HY StarTech.com 1 ft Panel Mount USB Cable A to A - F/M In Stock £4.21
