Fast charge your mobile devices such as tablets (iPad, Samsung, etc.) or smartphones from any USB 2.0 port. The USB2CHADP USB 2.0 Fast Charging Adapter transforms your computer USB host port into a charge-only port, enabling the adapter to charge your mobile devices (iPad, Samsung Tablet, etc.) as an AC wall charger would, and ultimately decreasing your charge times which makes it perfect for people on the move.
The USB charger adapter also includes a switch that allows you to shift between data / sync mode and fast charge mode. The LED indicator on the adapter will change from Red when in fast charge mode to Blue when in data transfer mode.
- StarTech.com USB 2.0 Fast Charging Adapter A-A - Sync / Fast Charge Switch - USB charge adapter - USB (power only) to USB
- Connector
- 4 pin USB Type A (power only) - female
- Connector (Second End)
- 4 pin USB Type A - male
- Black
- 2-year warranty
- Designed For
- P/N: USB2ADC1M, USBLT1MBR, USBLT1MW, USBLT2MB, USBLT2MW, USBLT30CMW
- Plated Connector
- Nickel
- Black
- Connector
- RoHS
- 2-year warranty
- Designed For
