Your basket is empty
StarTech.com Universal USB 3.0 Laptop Mini Docking Station with VGA Gigabit Ethernet USB 3.0
Quicklinx: 9YYDWS00 Mfr#: USB3SMDOCKV
Easily create a workstation on the go and add video, Gigabit Ethernet, and a USB 3.0 port to any laptop. This travel docking station lets you turn your laptop into a mobile workstation. It's a travel-friendly solution that helps you connect extra devices to any computer, even when you're on the move.
With a lightweight design, this compact laptop docking station tucks neatly into your travel bag. Now, you can avoid the nuisance of carrying multiple adapters, by consolidating three essential connection ports into one convenient device.
Plus, the portable docking station complements your Ultrabook nicely, with an aesthetically matching black and silver housing.
Providing added distance flexibility via an integrated extended-length (21") USB 3.0 host cable, you can easily connect a VGA monitor as a second display.
The versatile docking station also adds Gigabit Ethernet and a USB 3.0 port to your laptop, letting you set up a multi-functional workstation on the run. Plus, you don't have to worry about sacrificing one of your laptop USB ports.
To save you time, setup is seamless and hassle-free. The travel dock automatically downloads the latest driver when connected to a Windows system with an active network connection.
The universal travel docking station for laptops works with almost any USB 3.0 capable system. It's USB-powered too, so you can get up and running without the aggravation of searching for an available power outlet.
StarTech.com Universal USB 3.0 Laptop Mini Docking Station with VGA, Gigabit Ethernet, USB 3.0 - docking station
Docking station
Docking Interface
USB
6.8 cm x 10.6 cm x 2.5 cm
200 g
Gigabit Ethernet
3 years warranty
Docking station
6.8 cm
10.6 cm
2.5 cm
200 g
Enclosure Colour
Black, silver
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 2.0, USB 3.0
1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x display / video - output - 15 pin HD D-Sub (HD-15) , 1 x USB 2.0 - 5 pin Micro-USB Type B
1 x SuperSpeed USB cable - integrated - 53.4 cm
USB powered
FCC, RoHS
Apple MacOS X 10.6 or later, Microsoft Windows XP SP3, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
Limited warranty - 3 years
50 °C
9YYD StarTech.com DVI to VGA Cable Adapter - Black - F/M In Stock £5.66
9YYD StarTech.com 6 ft Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.13
9YYD StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £5.75
9YYD StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £11.23
