Add a Gigabit Ethernet RJ45 port and HDMI output to your port-limited laptop, through a single USB 3.0 port. The USB31GEHD USB 3.0 Mini Docking Station Adapter lets you add Gigabit Ethernet and HDMI connection ports to your Ultrabook, laptop, or desktop through a single USB 3.0 host, giving you two connectivity ports that aren't always available on modern mobile computers.
Providing full Gigabit bandwidth for faster network connections, this adapter leverages the 5 Gbps capabilities of the USB 3.0 interface to support 10/100/1000 Mbps Ethernet and is fully compatible with IEEE 802.3/u/ab standards. Plus, the Gigabit adapter functions as an external graphics card, letting you add an external monitor in addition to your laptop display, with 2048x1152 video and 5.1 surround sound audio (from HDMI port only).
An ideal multi-port combo adapter for mobile or stationary environments with no external power adapter required, this USB-Powered adapter is the perfect laptop accessory that tucks neatly into your travel bag with a compact and portable design.
The mini docking station adapter ensures a quick and easy setup by automatically downloading the latest driver in Windows systems that have an active network connection, and offers backward compatibility with USB 2.0 systems (speed limited by USB bus).
- StarTech.com Universal USB 3.0 Mini Docking Station Adapter with Gigabit Ethernet and HDMI - docking station - USB - HDMI - GigE
- Product Type
- Docking station
- Docking Interface
- USB
- Video Interfaces
- HDMI
- 6.4 cm x 18 cm x 1.9 cm
- 45 g
- Black
- Networking
- Gigabit Ethernet
- 3-year warranty
- Product Type
- Docking station
- 6.4 cm
- 18 cm
- 1.9 cm
- 45 g
- Enclosure Colour
- Black
- Data Link Protocol
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 2.0, USB 3.0
- 1 x audio / video - HDMI - 19 pin HDMI Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
- Cables Included
- 1 x SuperSpeed USB cable - integrated - 10.1 cm
- USB powered
- RoHS
- OS Required
- Microsoft Windows XP (32-bit) SP3, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Apple MacOS X 10.6 - 10.13.3
- Limited warranty - 3 years
- 0 °C
- 40 °C
StarTech.com 25 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable | In Stock | £7.31 |
StarTech.com 15 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable | In Stock | £4.55 |
StarTech.com 6 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable | In Stock | £3.36 |
StarTech.com 6 ft Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.16 |
StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female | In Stock | £7.66 |
StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £5.83 |
StarTech.com Universal USB 3.0 Laptop Docking Station Dual-Monitor HDMI DVI | In Stock | £103.51 |
StarTech.com Universal USB 3.0 Laptop Docking Station - Dual Video HDMI DVI VGA with Audio | In Stock | £91.78 |
StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - Black | In Stock | £25.93 |
StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - White | In Stock | £26.31 |
StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI GbE | In Stock | £48.85 |
StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 | In Stock | £68.32 |
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £9.39 |
