Product
StarTech.com Universal Laptop USB Docking Station with VGA Audio Ethernet
Quicklinx: 6PG3WS00 Mfr#: USBVGADOCK2
4-in-1 Laptop docking station with VGA, Ethernet, dual audio and 4 port USB 2.0 connections. The USBVGADOCK2 is a combination USB VGA adapter and 4-in-1 docking station that converts a single USB 2.0 port into multiple connection ports, including: a VGA port, 10/100 RJ45 network connection, dual (3.5mm phono) audio ports and four additional USB 2.0 ports.
Compatible with a broad range of operating systems, including Microsoft Windows 7, the USB VGA adapter/docking station supports 1600x1200 (32-bit) display resolutions for connected VGA monitors and saves the time and hassle of having to disconnect devices like speakers and USB peripherals (scanners, printers, webcams etc.) in order to re-connect them to another computer. Using this convenient docking station makes it as simple as creating the single USB 2.0 host connection in order to access the connected peripherals.
StarTech.com Universal Laptop USB Docking Station w/VGA Audio Ethernet - docking station
Docking station
Docking Interface
USB
20.3 cm 1.9 cm
Fast Ethernet
Power adapter - external
3 years warranty
Docking station
20.3 cm
1.9 cm
Enclosure Colour
Ethernet, Fast Ethernet
4 x USB 2.0 - 4 pin USB Type A , 1 x display / video - output - 15 pin HD D-Sub (HD-15) , 1 x network - 10Base-T/100Base-TX - RJ-45 , 1 x headphones - output - mini-phone stereo 3.5 mm , 1 x microphone - input - mini-phone 3.5 mm , 1 x USB 2.0 - 5 pin Micro-USB Type B
FCC, RoHS
Limited warranty - 3 years
6PG3 StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.74
6PG3 StarTech.com 25 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £16.34
6PG3 StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £5.85
6PG3 StarTech.com 15 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £3.80
6PG3 StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.81
6PG3 StarTech.com 6 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.15
