StarTech.com Universal Ceiling Projector Mount - Up to 22.7" Extension
Quicklinx: FP9KWS00 Mfr#: PROJCEILMNT2
£104.13 ex VAT
£124.95 inc VAT
Universal Projector Ceiling Mount Up to 22.7" Extension from Ceiling Steel / Aluminum. This projector ceiling mount kit lets you easily install a projector from 5" to 22.7" (127.7 to 577.7 mm) away from the ceiling. It's ideal for classrooms, boardrooms, hospitality venues, and many other meeting spaces.
Wide Compatibility with Projectors
Supporting a wide range of projector brands, the universal projector ceiling mount features a universal mounting pattern of 12.8" (325 mm) diameter.
Fine-Tune for Optimum Viewing
After the projector ceiling mount is installed, you can fine-tune the angle for optimum viewing. The locking ball join on the projector mount provides 360-degree swivel, +/- 25 degree horizontal/vertical tilt.
Heavy-duty Steel and Aluminum Construction
With its robust steel and aluminum construction and solid wall plate, the ceiling mount projector stand supports a weight capacity of 33.3 lb. (15 kg). All hardware required for installation is included.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
PROJWALLMNT is backed by a StarTech.com 2-year warranty and free, lifetime technical support.
StarTech.com Universal Ceiling Projector Mount, Heavy Duty Height Adjustable/Extendable Pole Mount 5"-22.7" from Ceiling, 33lb (15kg), Tilt/Rotate, Hanging Projector Mount w/ Bracket - Telescopic Pole (PROJCEILMNT2) bracket - for projector - TAA Compliant
Bracket - ceiling mountable
57.77 cm x 35.2 cm x 35.25 cm
Adjustable Height
12.8-70.5 cm
Tilt
-5° to 5°
Swivel
360°
Adjustments
Height, tilt, swivel
2.2 kg
Recommended Use
Projector
Max Load Weight
15 kg
Material
Aluminium, heavy duty steel
TAA Compliant
Package Content
4 x washers, lower pole, 4 x mounting screws, upper pole, 4 x mounting arms, 4 x M3x24 screws, 4 x M4x24 screws, 4 x M5x24 screws, projector plate, projector plate cover, ball joint mechanism, 4 x wall anchors, 4 x mounting arm covers, 5mm hex screw, 7 x M6x12 screws, 4 x M6x24 screws, 2 x M6x65 screws, 6 x nuts
57.77 cm
35.2 cm
35.25 cm
Adjustable Height
12.8-70.5 cm
2.2 kg
Material
Package Content
AV Furniture
Bracket
Recommended Use
Projector
Placing / Mounting
Ceiling mountable
Cable Management
Integrated cable management
Tilt
-5° to 5°
Swivel
360°
Adjustments
Max Load Weight
15 kg
TAA Compliant
Dimensions & Weight Details
35.3 cm x 26.8 cm x 9.8 cm / 2.3 kg
