Quicklinx: D388WS00 Mfr#: ICUSB232C
Type: Serial adapter
Compatibility: PC
Interface: [N/A]
£16.71 ex VAT
£20.05 inc VAT
Connect an RS232 (DB9) peripheral to your USB-C device. This USB-C to serial adapter lets you connect your USB-C devices to your legacy serial equipment. It converts a USB-C port on your laptop or computer into a RS232 DB9 serial port, giving you a cost-saving way to connect to serial devices such as point-of-sale terminals, serial modems, industrial equipment, and a wide variety of other RS232 peripherals.
The RS232 adapter cable is compatible with Windows, macOS and Linux operating systems, which makes it easy to integrate into mixed environments.
The USB-C to serial adapter is USB powered, so you don't need an additional external power supply. It's a compact solution that's easy to bring along with your laptop, when you're on the go.
  • Connect with ease
    The RS232 adapter cable is compatible with Windows , macOS and Linux operating systems, which makes it easy to integrate into mixed environments.
  • Ready for mobile or desktop applications
    The USB-C to serial adapter is USB powered, so you don't need an additional external power supply. It's a compact solution that's easy to bring along with your laptop, when you're on the go. The ICUSB232C is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com USB C to Serial Adapter Cable 16" (40cm), USB Type C to RS232 (DB9) Converter Cable, USB-C Serial Cable for PLCs, Scanners, Receipt Printers, Male/Male, Windows/macOS/Linux - Up to 921.6 Kbps Baud - USB / serial cable - DB-9 to 24 pin USB-C - 40 cm
USB / serial cable
Thumbscrews, Chipset Prolific PL2303RA
Length
40 cm
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
24 pin USB-C - male
USB / serial cable
Length
40 cm
8 g
Connector
24 pin USB-C - male
WHQL
D388 StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £25.99
D388 StarTech.com 3ft USB to RS232 DB9 Serial Adapter Cable - M/M In Stock £21.04
D388 StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI In Stock £27.41
D388 StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.43
D388 StarTech.com USB to RS232 Serial Adapter In Stock £16.74
D388 StarTech.com USB C to RS232 Cable In Stock £22.67
Compatibility: PC
Interface: [N/A]
