StarTech.com U.2 to M.2 Adapter
Quicklinx: D0JSWS00 Mfr#: M2E4SFF8643
Type: Interface adapter
HD Size: 2.5"
14 in stock
£13.34 ex VAT
£16.00 inc VAT
Add U.2 PCIe NVMe SSD performance to your desktop computer or server, by connecting a U.2 SSD to an M.2 PCIe x4 host interface. This PCI Express U.2 to M.2 adapter makes it easy to install a high-performance U.2 PCIe-NVMe SSD into your desktop PC or server and connect the drive through an M.2 PCIe x4 slot on your motherboard. By creating compatibility with newer U.2 NVMe SSDs, such as the Intel SSD 750 series, this enterprise-class drive adapter enables you to gain faster read/write speeds and higher productivity levels for data-intensive applications.
This drive adapter card lets you optimize your system performance by harnessing the increased speed and low latency of a U.2 PCIe-NVMe SSD (compared to regular platter drives), by adding a U.2 interface to your system.
The U.2 to M.2 adapter is ideal for IT professionals, system integrators and installers, and enthusiasts who are building or upgrading a server or desktop computer. It's a cost-effective alternative that delivers the superior performance of newer U.2 NVMe SSDs, without the expense of replacing the system motherboard for the sake of compatibility.
The U.2 to M.2 adapter works with all desktop PCs and servers that have an M.2 PCIe x4 host interface. The adapter card is OS independent, so there are no drivers or software required for installation.
  • Gain faster system performance
    This drive adapter card lets you optimize your system performance by harnessing the increased speed and low latency of a U.2 PCIe-NVMe SSD, by adding a U.2 interface to your system.
  • Upgrade your system cost-effectively
    The U.2 to M.2 adapter is ideal for IT professionals, system integrators and installers, and enthusiasts who are building or upgrading a server or desktop computer. It's a cost-effective alternative that delivers the superior performance of U.2 NVMe SSDs, without the expense of replacing the system motherboard for the sake of compatibility.
  • Easy installation
    The U.2 to M.2 adapter works with all desktop PCs and servers that have an M.2 PCIe host interface. The adapter card is OS independent, so there are no drivers or software required for installation.
StarTech.com U.2 to M.2 Adapter - for 1 x U.2 PCIe NVMe SSD - M.2 PCIe x4 Host Interface - U.2 SSD - M.2 PCIe Adapter - U.2 Drive (M2E4SFF8643) - interface adapter - SAS - M.2 Card
Interface adapter - plug-in card
Bus Type
M.2 Card
Red
Hard Drive Form Factor Compatibility
2.5"
SAS
Supported Devices
Solid state drive
Max Storage Devices Qty
1
2.1 cm x 6.3 cm x 1.5 cm
8 g
2.5"
Host Bus
M.2 Card
Red
Storage Controller
SAS
Supported Devices
Solid state drive
1
1 x mini-SAS - 4 x Mini SAS HD (SFF-8643)
1 x M.2 Card
1 x screw
Supports NVM Express
FCC, RoHS, WEEE
2.1 cm
6.3 cm
1.5 cm
8 g
55 °C
15 - 90%
D0JS StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £16.33
D0JS StarTech.com M.2 SATA external SSD enclosure USB 3.0 with UASP In Stock £22.80
D0JS StarTech.com 2x M.2 SSD Controller - PCIe In Stock £49.18
D0JS StarTech.com Dual M.2 NGFF SATA Adapter w/ RAID - 2x M.2 SSDs to 2.5in SATA In Stock £34.65
D0JS StarTech.com U.2 2.5" NVMe SSD Adapter In Stock £22.11
D0JS StarTech.com U.2 to PCIe Adapter -SFF-8639 In Stock £27.64
D0JS StarTech.com U.2 to M.2 Adapter In Stock £13.34
D0JS StarTech.com M.2 to U.2 Adapter In Stock £22.13
HD Size: 2.5"
Price Range Ex VAT: 0 - 50
