StarTech.com Type C Single Video HDMI Dock with PD - UK & EU
Quicklinx: DZ70WS00 Mfr#: DK30CHDPDUE
Power and charge your laptop through USB Type-C, and create a workstation virtually anywhere you go by adding 4K HDMI display, plus GbE, and four USB 3.0 ports. This USB-C dock gives you all the connections you need to turn your USB-C enabled laptop or tablet into a fully capable workstation, with support for a single external 4K HDMI monitor or ultrawide monitor. With USB Power Delivery 2.0 (85W), you can power and charge your laptop as you work, eliminating the need to use a separate power adapter with your laptop. It's the perfect companion for your MacBook Pro or other Thunderbolt 3 equipped laptop or tablet.
The USB-C dock helps you maximize your workspace, ideal for smaller or shared work areas using one monitor. The dock expands the display capabilities of your laptop, connecting to an HDMI display with support for resolutions including: 4096x2160 @ 30Hz, 3840 x 2160 @ 30Hz, 2560x1600 @60 Hz, 1920 x 1200 @ 60Hz.
Create an immersive experience by connecting the USB-C dock to an ultrawide or ultrawide curved monitor with 21:9 aspect ratio (3440 x 1440p @ 60 Hz), to emulate a multi-display set-up and gain exceptional picture quality.
The dock provides four USB 3.0 (Type-A) ports to connect peripherals such as your mouse or keyboard. It also includes a USB 3.0 fast-charge and sync port, a Gigabit Ethernet port (with PXE Boot support), and a combined 3.5 mm audio and microphone port.
Compatible with Mac and Windows, this universal dock works with USB-C and Thunderbolt 3 enabled laptops.
StarTech.com USB-C Dock, USB Type-C Laptop Docking Station w/ Single 4K 30Hz HDMI, 85W Power Delivery, 4-Port USB 3.0 Hub, Gigabit Ethernet (GbE), Audio, Compact USB 3.1 Gen 1 Type-C Dock - USB-C Docking Station (DK30CHDPDUE) - docking station - USB-C / Thunderbolt 3 - HDMI - GigE
Docking station
Docking Interface
Video Interfaces
HDMI
9.1 cm x 9.8 cm x 3.2 cm
200 g
United Kingdom, Europe
Gigabit Ethernet
Power adapter 85 Watt Power Provided
3-year warranty
Docking station
9.1 cm
9.8 cm
3.2 cm
200 g
Enclosure Colour
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0
1 x USB-C - input - 24 pin USB-C , 1 x display / video - HDMI output - 19 pin HDMI Type A , 4 x SuperSpeed USB 3.0 - output - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x audio - output - mini-phone 3.5 mm 4-pole
1 x USB-C cable - external - 1 m
UASP transfer protocol, 1 USB 3.0 fast charging port, auto MDIX support
USB Battery Charging Specification Rev. 1.2, USB Power Delivery 2.0, DisplayPort 1.2
Power adapter
Power Provided
85 Watt
Apple MacOS X 10.11 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years
Shipping Weight
1 kg
DZ70 StarTech.com 3.5mm 3 Pin Headset Splitter In Stock £6.39
DZ70 StarTech.com Dual 4K Docking Station, Mac & Windows - USB-A & USB-C Dock, Dual 4K60 DP & HDMI In Stock £134.82
