StarTech.com Two Way Digital Coax to Toslink Optical Audio Converter Repeater
Quicklinx: 7RXQWS00 Mfr#: SPDIFCOAXTOS
Type: Signal Converter
Hurry, only 1 left in stock!
£39.52 ex VAT
£47.42 inc VAT
Convert an SPDIF audio source signal to Digital Coax and Toslink either separately or simultaneously. The SPDIFCOAXTOS Two way Digital Coax to Toslink Audio Converter Repeater lets you extend and convert digital coax to Toslink audio, or Toslink to digital coax.
This small form-factor coax toslink converter is an easy to use solution allows you to select the input signal you want to convert or extend, and simultaneously outputs both digital coaxial and Toslink audio signals without downgrading the audio signal, and provides an output signal that matches the quality of input audio, supporting 2 to 5.1 channel audio.
StarTech.com Two Way Digital Coax to Toslink Optical Audio Adapter Repeater - coaxial/optical digital audio converter
Coaxial/optical digital audio converter
White
1-year warranty
P/N: SVA5M3NEUA
White
Digital audio input (coaxial) - RCA , Digital audio input (optical) - TOS Link , Digital audio output (coaxial) - RCA , Digital audio output (optical) - TOS Link
1 year
P/N: SVA5M3NEUA
7RXQ StarTech.com DC Power Adapter - 5V, 3A In Stock £10.83
Price Range Ex VAT: 0 - 50
