StarTech.com TV Wall Mount - Steel
Quicklinx: CRYMWS00 Mfr#: FPWARTB2
Hurry, only 1 left in stock!
£163.93 ex VAT
£196.71 inc VAT
Free up space by mounting your flat-panel TV on a wall, with full-motion adjustment capability. Maximize space while creating an impressive display. With its dual-arm design, this heavy-duty TV wall mount securely supports large flat-screen TVs up to 70". The arms are easy to extend, to provide smooth, full-motion positioning for ideal viewing.
Mount your flat-screen TV in a location that's convenient for visitors, clients and employees, and frees up valuable space. The wall mount is ideal for the lobby, boardroom or other venues, providing an impressive and secure way to display a large flat-panel TV or create digital signage. The TV wall mount supports most 32" to 70" (812.8 to 1778 mm) LED or LCD flat panel TVs weighing up to 99 lb. (45 kg).
The TV wall mount provides full-motion adjustment capability. The dual-arm extends up to 20.3" (517 mm) from the wall to provide a wide range of movement and accommodate different screen positions and angles. The dual-arm can also fold to tuck-in closely to the wall, providing a low profile that enables your display to be positioned just 2.24" (57 mm) from the wall.
The TV wall mount swivels +90° / -90° to provide maximum viewing flexibility. The mount also tilts +5° / -8°, letting you angle your TV display toward your audience. With the tilt feature, you can mount your TV lower or higher than eye level and still view it comfortably. A built-in level adjustment also offers 5° clockwise and counterclockwise turning, to ensure your display is perfectly level.
The robust steel TV wall mount, with its dual-arm design and dual-stud mounting for studs placed 16" apart, provides increased durability and security. It safely and securely supports your flat-screen TV, to protect your investment. The TV wall mount also includes built-in cable management to keep cables neatly out of sight.
  • Save Space
    Mount your flat-screen TV in a location that's convenient for visitors, clients and employees, and free up valuable space. The wall mount is ideal for a lobby, boardroom or other venue. The TV wall mount also includes built-in cable management to keep cables neatly out of sight.
  • Full-Motion Adjustment
    The TV wall mount features dual arms that extend out to 20.4" (517 mm) from the wall to provide a wide range of movement and accommodate different screen positions and angles. The arms can also fold to tuck in closely to the wall, providing a low profile that enables your display to be positioned just 2.24" (57 mm) from the wall. You can swivel your display +90 / -90 degrees and tilt +5 / -8 degrees, letting you angle your TV display toward your audience. Plus, the tilt feature lets you adjust the TV so that you can view it comfortably at any height. A built-in level adjustment also offers 5 degree clockwise and counterclockwise turning, to ensure your display is perfectly level.
StarTech.com TV Wall Mount supports up to 70 inch VESA Displays, Low Profile Full Motion Universal TV Flat Screen Wall Mount Heavy Duty Adjustable Tilt/Swivel Articulating Arm Bracket - Cable Management (FPWARTB2) mounting kit - for TV - black
Mounting kit - wall-mountable
Mounting Components
Wall mount, wrench, 2 vertical brackets, 2 horizontal brackets
Tilt
-8° to 5°
Pan
-90° to 90°
Adjustments
Levelling, swivel
Recommended Use
TV
Recommended Display Size
32"-70"
VESA Mounting Interface
200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 300 x 200 mm, 300 x 300 mm, 400 x 600 mm
Max Load Weight
45 kg
Material
Plastic, steel
Package Content
4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 8 x washers, 4 x M8x50 screws, 4 x bracket screws, 4 x nuts, 2 x mounting screws, 16 x spacers, 6 x screws, 6 x concrete screws, 6 x bracket washers
5-year warranty
P/N: HDMIPLATE
Material
Plastic, steel
Package Content
AV Furniture
Mounting kit
Mounting Components
Recommended Use
TV
Placing / Mounting
Wall-mountable
Cable Management
Integrated cable management
32"-70"
Tilt
-8° to 5°
Pan
-90° to 90°
Adjustments
Levelling, swivel
Max Load Weight
45 kg
Limited warranty - 5 years
P/N: HDMIPLATE
