StarTech.com TV Wall Mount - Fixed
Quicklinx: F2GFWS00 Mfr#: FPWFXB1
35 In Stock
£61.74 ex VAT
£74.08 inc VAT
Save space and create an impressive display by wall-mounting a large TV in a boardroom or customer-facing area. This fixed flat-screen TV wall mount securely supports a TV up to 100" and features an attractive low-profile design.
Mount your large flat-screen TV in a location that's convenient for visitors, clients and employees. Create an engaging display to keep guests informed or entertained, ideal in lobbies, lecture halls, restaurants, health care centers and other meeting spaces.
The television wall mount supports most 60" to 100" (812.8 to 1778 mm) LED or LCD flat panel TVs weighing up to 165 lb. (75 kg). It also supports curved TVs, with a compatible VESA mount up to 900x600.
Save space with this slim TV wall mount. With its low-profile design, your TV sits just 1.2" (30.5 mm)from the wall.
The heavy-duty TV mounting bracket securely supports your large flat-screen TV and is easy to install. The spring locks allow quick attachment and release. The open architecture provides ventilation and easy access to wires.
  • Engineered forHeavy DutyCommercial Grade TVs
    This TV wall mount isdesigned to be used with commercial orheavy-dutytelevisions and displays. It supports a weight of up to 165lbs.or 75 kilograms and has beenthoroughly tested totripletheratedweightcapacityto ensure premium product qualityand reliable performance. The mount is ideal for 60"to 100"TVsincluding curved TVs; however,mostlargeror smaller TVs can be accommodatedif they fall within the listed weight capacity.
  • Straightforward Installation & Removal
    This TV mountis VESA compatible andhastwo rows of seventeenmounting holes across thewall brackettoaccommodate a variety ofspacing between studsandhelping you to center your display.The included bubble level helpsto ensurean accuratemountto the wall. Once thewallbracketis attached to the walland the vertical brackets are attached to theTV, theTVsimply attaches to the mount using the spring locks and can be as easily removed using therelease pull straps.
StarTech.com Flat Screen TV Wall Mount - Fixed - Heavy Duty Commercial Grade TV Wall Mount for 60" to 100" TVs - VESA Wall Mount (FPWFXB1) bracket - for TV - black
Bracket - wall-mountable
62.5 cm x 95.4 cm x 3.05 cm
3.5 kg
Recommended Use
TV
Recommended Display Size
60"-100"
VESA Mounting Interface
200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 600 x 400 mm, 300 x 200 mm, 600 x 600 mm, 800 x 600 mm, 900 x 600 mm, 300 x 300 mm
Max Load Weight
75 kg
Material
Plastic, steel
Package Content
4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 8 x spacers (small), 6 x concrete anchors, 4 x M8x50 screws, 4 x rectangular washers, 2 x vertical brackets, 8 x spacers (large), level, 6 x washers, 6 x wall screws
62.5 cm
95.4 cm
3.05 cm
3.5 kg
Material
Plastic, steel
Package Content
AV Furniture
Bracket
Recommended Use
TV
Placing / Mounting
Wall-mountable
60"-100"
Max Load Weight
75 kg
Dimensions & Weight Details
3.7 kg
