Increase productivity and free up space by mounting three monitors to this desktop stand. This free-standing triple-monitor stand saves you valuable desk space, while creating a more comfortable and ergonomic workspace. Constructed of high grade steel, the sturdy monitor stand suspends up to three monitors above your desk or other work surface.
Clear up your desk surface while creating an ergonomic workspace. This computer monitor stand enhances your efficiency and productivity, by supporting three displays 13" to 27" (330 to 686 mm) in size and 17.6 lb. (8 kg) in weight per monitor. It's ideal for offices, control rooms, banking, real estate and other real-time environments where multiple monitors are essential to productivity.
Easily rotate up to 360°, tilt up to 45° up or down and swivel + 45° / -45° to adjust your screen position. The structure allows smooth, effortless rotating and positioning for any direction, making it easy to reduce glare and find the ideal viewing angle. The micro-adjustment features enables level alignment of your three monitors. You can also adjust the height of your monitor along the vertical pole, with maximum height adjustment of 17.7" (450 mm), to reduce neck and eye strain.
The heavy-duty steel monitor stand with solid steel base holds your monitors securely and provides long-lasting performance. The surface finish features a powder coating to help resist scratches.
The monitor stand is designed for easy installation on your desk, table or other work surface. For easier mounting, the VESA mount features notches that let you pre-set the mounting screw, then slide the monitor in place and tighten the screw. To help keep your work area free of clutter, the monitor stand also features cable clips that keep your cables neatly out of sight.
- StarTech.com Triple-Monitor Desktop Stand stand - adjustable arm - for LCD display
- Product Type
- Stand (adjustable arm) - stand mountable
- Mounting Components
- Pole, base plate, crossbar, washers, screws, collar, VESA mount bracket, 6 x cable management clips
- Rotation
- 360°
- Adjustments
- Height, pan, tilt
- Recommended Use
- LCD display
- Recommended Display Size
- 13"-27"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 8 kg
- Package Content
- M4x12 screws, hex key (3mm), hex key (5mm), hex key (6mm), M5x12 screws
- 2-year warranty
- Package Content
AV Furniture
- Stand
- Design
- Adjustable arm
- Recommended Use
- LCD display
- Placing / Mounting
- Stand mountable
- Cable Management
- Integrated cable management
- 13"-27"
- Rotation
- 360°
- Adjustments
- Height, pan, tilt
- Max Load Weight
- 8 kg
- Limited warranty - 2 years
