StarTech.com Triple Head DisplayPort Multi Monitor Adapter
Quicklinx: 8G4FWS00 Mfr#: SP123DP
The SP123DP Triple Head DisplayPort Multi Monitor Graphics Expansion Module/Adapter is an external multi-monitor spanner/splitter that lets you add multiple displays (up to three) to a desktop or laptop PC, from a single DisplayPort source.
This versatile graphics expansion module enables you to combine 3 DisplayPort monitors as a single display, for a panoramic multi-display setup at resolutions up to 3840x1024 - all without opening the computer case. The expansion module also lets you clone (mirror) your primary display, using the device as a 3-port DisplayPort splitter.
Compatible with a DisplayPort video card and displays, the graphics expansion module requires no software installation for multi-display applications, simplifying configuration and saving time.
StarTech.com Triple Head DisplayPort Multi Monitor Adapter - video splitter - 3 ports
Video splitter - 3 ports
AC 100/230 V
6.5 cm x 13.1 cm x 2.6 cm
270 g
P/N: SVA5N3NEUA
Enclosure Type
Desktop
Max Resolution
3840 x 1200
Status Indicators
Display / video: 3 x DisplayPort output - 20 pin DisplayPort , Display / video: 1 x DisplayPort input - 20 pin DisplayPort
External power adapter
AC 100/230 V
FCC, RoHS
6.5 cm
13.1 cm
2.6 cm
270 g
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
P/N: SVA5N3NEUA
8G4F StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £24.19
8G4F StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.12
8G4F StarTech.com DisplayPort to DVI Active Adapter In Stock £22.91
