Connect three 4K monitors to your Windows or MacBook laptop through USB-C (5Gbps), plus power and charge as you work. This USB-C docking station for MacBook and Windows laptops takes productivity to a whole new level, with support for triple 4K monitors - a first in the market. The triple 4K docking station supports Ultra HD 4K resolution on two DisplayPort monitors (at 60Hz), and on one HDMI monitor (at 30Hz).
The docking station also features USB Power Delivery, so you can power and charge your MacBook or Windows-based laptop as you work while powering your peripherals, using the included 120W power adapter. Through just one USB Type-C cable, the dock also provides access to a wired network and five USB ports. It's a must-have accessory for your MacBook Pro, Chromebook Pixel, Dell XPS 15, or other USB-C enabled laptop.
This premium docking station lets you create a multi-monitor Ultra HD workstation with three monitors, even if your laptop video card doesn't natively support it. The USB-C dock offers a fast and easy way to maximize your laptop's workable screen space, giving you four screens in total when coupled with your laptop's display.
Compatible with both Windows and MacBook computers, this universal laptop dock works with many USB-C enabled laptops. You simply connect to your laptop's USB-C port to get up and running quickly.
Because the dock uses USB-C, the dock is Thunderbolt 3 port compatible, you can connect it to your Thunderbolt 3 equipped laptop. For the MacBook Pro, this docking station provides a strong alternative to Thunderbolt 3 docks, to meet your charging needs and high-quality display requirements.
With support for USB Power Delivery 2.0, the docking station powers and charges your laptop, and powers other connected devices, from a single power adapter.
The included 120W power adapter provides up to 60W for charging your MacBook or Windows based laptop while maximizing the additional power available to all peripherals and devices connected to the dock.
This triple-video docking station lets you connect your favorite peripherals, to transform your laptop into a powerful, full-sized workstation. With five USB 3.0 ports (4x USB Type-A and 1x USB Type-C), a Gigabit Ethernet port, headset jack, plus separate 3.5 mm audio and microphone ports for multiple audio, you have all the connections you need to maximize performance. The dock also includes a BC 1.2 charging Type-A port for fast charging your smartphone.
Enhance productivity
The 4K USB-C dock for Mac and Windows lets you create a three-monitor Ultra HD workstation. -
Powerful connections
This triple-monitor docking station lets you connect your peripherals to transform your laptop into a full-sized workstation. With five USB 3.0 ports, a Gigabit Ethernet port, headset jack and separate 3.5 mm audio and microphone ports, you have all the connections you need for maximum performance. -
60W Power Delivery
Using a single cable, the USB-C docking station with Power Delivery will power and charge your laptop, and power your peripherals with its 120W power adapter.
- StarTech.com 4K USB-C Dock - Triple Monitor - Mac & Windows - 60W USB PD (DK30CH2DPPDU) - docking station - USB-C - HDMI, 2 x DP - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- HDMI, 2 x DP
- 8.2 cm x 27 cm x 3.4 cm
- 385 g
- Black, silver
- Localisation
- United Kingdom, Europe
- Networking
- Gigabit Ethernet
- Power
- Power adapter AC 120/230 V 60 Watt Power Provided
- 3-year warranty
- Product Type
- Docking station
- 8.2 cm
- 27 cm
- 3.4 cm
- 385 g
- Enclosure Colour
- Black, silver
- Localisation
- Data Link Protocol
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0
- 2 x display / video - DisplayPort - 20 pin DisplayPort , 1 x display / video - HDMI - 19 pin HDMI Type A , 4 x SuperSpeed USB 3.0 - 9 pin USB Type A , 2 x USB-C - 24 pin USB-C , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x headphones - mini-phone 3.5 mm , 1 x microphone - mini-phone 3.5 mm , 1 x headset - mini-phone 3.5 mm 4-pole
- Cables Included
- 1 x USB-C cable - external
- Security lock slot (cable lock sold separately), 1 USB 3.0 fast charging port, full duplex support
- FCC, RoHS, WEEE, RCM, USB Battery Charging Specification Rev. 1.2, USB Power Delivery 2.0, DisplayPort 1.2, UASP (USB Attached SCSI Protocol)
- Power Device
- Power adapter
- Voltage Required
- AC 120/230 V
- Power Provided
- 60 Watt
- OS Required
- Apple MacOS X 10.9 - 10.12, Google Chrome OS 55 or later, Ubuntu 18.04, Ubuntu 20.04, Apple macOS 11.0, Apple macOS 10.14 - 10.15, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- Limited warranty - 3 years
- 0 °C
- 60 °C
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £15.98 |
StarTech.com 2m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £12.32 |
StarTech.com 3m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £24.60 |
StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M | In Stock | £11.42 |
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £8.38 |
StarTech.com 6 ft DP to HDMI cable - 4K | In Stock | £15.82 |
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £9.82 |
StarTech.com Triple-Video Laptop Dock | In Stock | £100.82 |
StarTech.com USB-C USB-A Dock - Hybrid Triple Monitor Docking Station DP/HDMI 4K 60Hz 85W PD | In Stock | £187.93 |
