StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter
Quicklinx: 95QDWS00 Mfr#: MDP2VGDVHD
More than 50 in stock
£33.01 ex VAT
£39.61 inc VAT
Connect a Mini DisplayPort-equipped PC or Mac to an HDMI, VGA, or DVI Display. This travel adapter lets you connect your mDP enabled Ultrabook or laptop computer to any VGA or HDMI display. The 3-in-1 Mini DisplayPort adapter is the perfect accessory for your Microsoft Surface Pro 4, Surface Pro 3, Surface 3 Surface Pro 2 or Surface Book.
Why carry multiple adapters when you only need one? Instead of keeping three different adapters on-hand, the mDP travel adapter offers VGA, DVI and HDMI outputs, so you'll be able to connect from your laptop mDP output to any modern boardroom or classroom display - an ideal plug-and-play solution for BYOD (Bring Your Own Device) applications at the office.
Plus, because the converter supports video resolutions up to 1920x1200 or 1080p you can convert a Mini DisplayPort video source to HDMI, VGA or DVI without sacrificing video quality.
The travel A/V adapter maximizes portability with a small footprint and lightweight design. The convenient design ensures the adapter is as portable as your laptop, fitting easily into your laptop bag or carrying case and eliminates the need to carry more than one adapter. With this adapter you can walk into virtually any boardroom ready to present, making a great first impression, and saving you the embarrassment of having to rummage through your bag looking for the right connector.
The 3-in-1 converter is compatible with the Intel Thunderbolt port on your computer and installs easily with no software or drivers required.
StarTech.com 3 in 1 Mini DisplayPort Adapter - 1080p - Mini DP / Thunderbolt to HDMI / VGA / DVI Splitter for Your Monitor (MDP2VGDVHD) - video converter - black
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - Mini DisplayPort , 1 x HDMI output - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x DVI-D output - 24+1 pin digital DVI
10 cm x 4.5 cm x 1.5 cm
Enclosure Colour
3-year warranty
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - Mini DisplayPort - male , 1 x HDMI output - 19 pin HDMI Type A - female , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female , 1 x DVI-D output - 24+1 pin digital DVI - female
FCC, RoHS
10 cm
4.5 cm
1.5 cm
51 g
Enclosure Colour
Limited warranty - 3 years
70 °C
10 - 85%
95QD StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.82
95QD StarTech.com 6 ft DVI-D Single Link Cable - M/M In Stock £6.86
95QD StarTech.com 15 ft DVI-D Single Link Cable - M/M In Stock £13.72
95QD StarTech.com 6 ft DVI-D Dual Link Cable - M/M In Stock £6.71
95QD StarTech.com 18in DVI-D Single Link Cable - M/M In Stock £5.02
95QD StarTech.com 20 ft Coax High Resolution Monitor VGA Cable HD15 M/M In Stock £9.79
95QD StarTech.com 10 ft DVI-D Single Link Cable - M/M In Stock £7.98
95QD StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter In Stock £19.10
95QD StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.22
95QD StarTech.com 10m (33 ft) Active CL2 In-wall High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable In Stock £50.52
95QD StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.09
95QD StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter In Stock £33.01
95QD StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black In Stock £33.01
95QD StarTech.com Travel A/V Adapter: 3-in-1 Mini DisplayPort to VGA DVI or HDMI In Stock £33.01
95QD StarTech.com mDP to HDMI or VGA Converter In Stock £18.11
95QD StarTech.com mDP to HDMI or VGA Converter In Stock £13.32
95QD StarTech.com DP to HDMI or VGA Converter In Stock £15.43
95QD StarTech.com mini DisplayPort to VGA DVI or HDMI Adapter In Stock £41.48
Price Range Ex VAT: 0 - 50
