Product
StarTech.com Thunderbolt to eSATA plus USB 3.0 Adapter USB 3.0 / eSATA 6Gb/s - Thunderbolt
Quicklinx: 9ZR8WS00 Mfr#: TB2USB3ES
Add an eSATA port and a USB 3.0 hub port to your Thunderbolt -equipped MacBook or laptop. The TB2USB3ES Thunderbolt to eSATA + USB 3.0 Adapter lets you expand your MacBook or laptop connectivity by combining Thunderbolt to eSATA and Thunderbolt to USB 3.0 functionality into a single, compact adapter. You gain two vital interfaces that are unavailable or limited on most Thunderbolt-equipped systems, delivering fast, reliable performance, more connection possibilities, and rugged portability.
Experience fast, effective and reliable performance from your essential peripherals! Now, you can leverage the 10 Gbps bandwidth of your Thunderbolt port to create a scalable, high-speed solution that offers eSATA and USB 3.0 connectivity.
To maximize efficiency, two dedicated lanes connect the Thunderbolt adapter directly to your system PCIe bus. Each lane delivers 5 Gbps bandwidth so you effectively avoid performance bottlenecks when both ports are in use. This versatile adapter gives you fast, simple and reliable external connectivity, offered by revolutionary Thunderbolt technology.
Take full advantage of your current peripherals! Saving you the added expense of purchasing new devices, this single adapter lets you simultaneously connect your existing peripherals through your Thunderbolt port - perfect for eSATA external hard drives (with SATA III support), as well as USB 3.0 hubs (with UASP support), or for syncing with your tablet or smartphone.
You can even integrate the adapter into the end of a Thunderbolt daisy-chain configuration! Connect the adapter to your Thunderbolt Docking Station (SKU: TBDOCKHDPBC - sold separately), for further MacBook expandability!
Get work done on the go, and look great doing it! A rugged and travel-friendly design lets you tuck the adapter neatly into your laptop bag, plus the casing combines portability with durability to offer quality protection that lets you take the adapter anywhere.
This sleek and stylish Thunderbolt adapter aesthetically matches your MacBook Pro or MacBook Air, with a silver sandblast finish and black rubberized grips. Plus, the compact adapter requires no external power, and integrates a built-in Thunderbolt cable as well as hassle-free plug-and-play installation.
StarTech.com Thunderbolt to eSATA plus USB 3.0 Adapter - Thunderbolt Adapter - storage controller - USB 3.0 / eSATA 6Gb/s - Thunderbolt
Storage controller - external
Bus Type
Thunderbolt
Silver
Data Transfer Rate
10 GBps
Supported Devices
Hard drive
Max Storage Devices Qty
1
Windows 8, Windows 8.1, Apple MacOS X 10.8.4 or later, Windows 10 (32/64 bits)
4.85 cm x 8.1 cm x 2.05 cm
92 g
Host Bus
Thunderbolt
Silver
Storage Controller
Data Transfer Rate
10 GBps
Supported Devices
Hard drive
1
ASMedia ASM1061
1 x eSATA 6Gb/s - eSATA , 1 x USB 3.0 - USB Type A
1 x Thunderbolt input
1 x Thunderbolt cable - integrated - 13 cm
FCC, RoHS
4.85 cm
8.1 cm
2.05 cm
92 g
-10 °C
55 °C
9ZR8 StarTech.com 3 ft Shielded External eSATA Cable M/M In Stock £6.82
9ZR8 StarTech.com 6 ft Shielded External eSATA Cable M/M In Stock £9.22
9ZR8 StarTech.com 6 ft Black SuperSpeed USB 3.0 Cable A to B - M/M In Stock £4.84
9ZR8 StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £5.73
9ZR8 StarTech.com USB 3.0/eSATA Dual 3.5" SATA III Hard Drive External RAID Enclosure w/ UASP - Black In Stock £62.49
9ZR8 StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) In Stock £42.07
9ZR8 StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £37.70
