StarTech.com Thunderbolt Hard Drive Enclosure with Thunderbolt Cable - Dual Bay 2.5" HDD Enclosure
Quicklinx: 9C4VWS00 Mfr#: S252SMTB3
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Add two 2.5" SATA HDDs, up to 15mm in height, to your Mac or PC through Thunderbolt, with a well-ventilated storage solution that helps keep your drives running cool. The S252SMTB3 2-bay enclosure features thunderbolt technology that maximizes the performance of your external drives by enabling you to connect two 2.5" SATA I/II/III hard drives (HDD) or solid state drives (SSD) to your Mac or PC using an available Thunderbolt port.
Transfer data to and from your external drives faster than ever before, through a Thunderbolt connection. With data transfer speeds up to 10 Gbps, Thunderbolt performs 100% faster than USB 3.0 (5 Gbps), and 60% faster than eSATA (6Gbps). The unprecedented performance thunderbolt offers makes this enclosure an ideal solution for high-resolution video editing and photography applications.
To save you time and money, the S252SMTB3 includes a high-quality 1m Thunderbolt cable, ensuring you have everything you need for a hassle-free installation.
To help ensure optimal operating temperatures for your hard drives and solid state drives, the Thunderbolt enclosure features a built-in fan and a durable, solid aluminum housing that maximizes heat dissipation.
Get the most out of your Thunderbolt technology by leveraging its daisy chain port. You can connect up to 6 additional devices such as monitors, docking stations, or additional external drives. This is an excellent docking solution for Ultrabooks or smaller more portable laptops that have fewer I/O ports.
StarTech.com Thunderbolt Dual Hard Drive Enclosure with Thunderbolt Cable - storage enclosure - SATA 6Gb/s - Thunderbolt
Storage enclosure - external
Bus Type
Thunderbolt
Silver
Expansion Bays
2 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 6Gb/s
Data Transfer Rate
10 GBps
Supported Devices
Hard drive
Max Storage Devices Qty
2
Product Material
Aluminium
Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
9.3 cm x 13.3 cm x 6.3 cm
490 g
P/N: SVA12M5NA, TB2DOCK4K2DP
2.5"
Host Bus
Thunderbolt
Product Material
Aluminium
Silver
Storage Controller
SATA 6Gb/s
Data Transfer Rate
10 GBps
Supported Devices
Hard drive
2
Bays
2 x internal - 2.5"
2 x SATA 6Gb/s - SATA combo
1 x Thunderbolt output
1 x Thunderbolt cable - external
Built-in cooling fan
FCC, RoHS
Power adapter
9.3 cm
13.3 cm
6.3 cm
490 g
5 °C
35 °C
5 - 95%
9C4V StarTech.com 1m (3 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k In Stock £14.48
9C4V StarTech.com 2m (6 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k In Stock £16.38
9C4V StarTech.com 3m (10 ft) White Mini DisplayPort Cable - M/M In Stock £17.45
9C4V StarTech.com 2.5in Aluminum USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP for SATA 6 In Stock £23.45
