StarTech.com Thunderbolt 3 to Dual DP - 4K
Quicklinx: CZCKWS00 Mfr#: TB32DP2T
12 in stock
£77.27 ex VAT
£92.72 inc VAT
This high-performance Thunderbolt 3 adapter lets you add two 4K 60Hz DisplayPort monitors to your Windows or Mac computer through a single Thunderbolt 3 port, or it can be used to connect your Thunderbolt 3 port to a 5K 60Hz display using two DP cables.
The Thunderbolt video adapter is compatible with computer systems that support Thunderbolt 3. Thunderbolt 3 is a protocol that uses the USB-C connector, but your computer system must support Thunderbolt 3 in order for the adapter to function as expected. If you connect the adapter to a USB-C port that does not support Thunderbolt 3, the adapter will not function.
StarTech.com Thunderbolt 3 to Dual DisplayPort Adapter - 4k 60Hz, 5k 60Hz - Certified TB3 to DP Monitor Adapter - Mac and Windows Compatible (TB32DP2T) - external video adapter - silver
External video adapter
Bus Type
Thunderbolt 3
Max Resolution
4096 x 2160
2 x DisplayPort
8 cm x 22 cm x 2.6 cm
Enclosure Colour
Silver
Bus Type
Thunderbolt 3
Max Resolution
4096 x 2160 at 60 Hz
2 x DisplayPort
Windows 8 / 8.1 / 10, Apple macOS Sierra 10.12
FCC, RoHS
8 cm
22 cm
2.6 cm
500 g
Enclosure Colour
Silver
CZCK StarTech.com Thunderbolt 3 to Dual DP - 4K In Stock £77.27
CZCK StarTech.com Thunderbolt 3 to Dual HDMI 4K In Stock £99.41
Price Range Ex VAT: 50 - 100
