StarTech.com Thunderbolt 3 to Dual DP - 4K
Quicklinx: CZCKWS00 Mfr#: TB32DP2T
£77.69 ex VAT
£93.22 inc VAT
This high-performance Thunderbolt 3 adapter lets you add two 4K 60Hz DisplayPort monitors to your Windows or Mac computer through a single Thunderbolt 3 port, or it can be used to connect your Thunderbolt 3 port to a 5K 60Hz display using two DP cables.
The Thunderbolt video adapter is compatible with computer systems that support Thunderbolt 3. Thunderbolt 3 is a protocol that uses the USB-C connector, but your computer system must support Thunderbolt 3 in order for the adapter to function as expected. If you connect the adapter to a USB-C port that does not support Thunderbolt 3, the adapter will not function.
  • Supports dual 4K displays to work more efficiently
    Functioning as an external 2-port graphics adapter with audio support, this is a compact and convenient alternative to a laptop dock when you don't need full docking capability. With two UHD 4K displays, you can work more efficiently from your laptop, so you can accomplish more in the same amount of time. Plus, with each display delivering 4K performance, you can have four times the screen space compared to 1080p. Creative professionals can be more productive with the freedom to edit 4K video on one display while previewing raw video playback on the second 4K display.
  • Won't drain system resources
    This adapter helps to keep your system running at peak performance. Unlike USB external video solutions, Thunderbolt 3 lets you run Ultra HD 4K resolution at 60Hz on both displays without draining system resources. Because it's backward compatible with your high-definition 1080p displays, this is a great accessory for home, office or other desktop workspace applications. The TB32DP2T is backed by a 2-year StarTech.com warranty and free lifetime technical support. Your computer's Thunderbolt 3 ports might not function properly until you update one or more of the following on your computer: • BIOS • Thunderbolt firmware • Thunderbolt 3 controller drivers • Thunderbolt 3 software The required updates will vary depending on your computer. If your manufacturer isn't listed on the Thunderbolt website, contact your manufacturer. Notes: •Text | If you're using a video adapter to connect this device to a monitor other than DisplayPort, such as HDMI or VGA, an active video adapter is required. •Text | In order to connect to two displays at 4K 60Hz, your computer system must have a fully enabled Thunderbolt 3 port that supports up to 40Gbps or the host must support dual displays over Thunderbolt 3.
StarTech.com Thunderbolt 3 to Dual DisplayPort Adapter 4K 60Hz, Thunderbolt 3 Certified, Dual Monitor DisplayPort 1.2 Video Converter, Compatible with Mac & Windows, Dual 4K DisplayPort - TB3 to Dual DP Display (TB32DP2T) - USB / DisplayPort adapter - 24 pin USB-C to DisplayPort - 30 cm
5K support, active adapter
Length
30 cm
Connector
24 pin USB-C - male (input)
Connector (Second End)
2 x 20 pin DisplayPort - female (output)
Thunderbolt 3
Silver
P/N: TB33A1C
Jacket Material
Plastic
Length
30 cm
Silver
6 cm
11 cm
1.5 cm
93 g
Connector
Thunderbolt 3, FCC, RoHS, WEEE, REACH, RCM
Shipping Width
14.5 cm
Shipping Depth
21.2 cm
Shipping Height
4 cm
Shipping Weight
221 g
P/N: TB33A1C
CZCK StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £24.19
CZCK StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £15.80
CZCK StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.12
CZCK StarTech.com DisplayPort to DVI Active Adapter In Stock £22.91
CZCK StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £16.29
CZCK StarTech.com DP to VGA Adapter with Audio In Stock £23.64
CZCK StarTech.com DisplayPort to HDMI - 4K 60Hz In Stock £23.58
CZCK StarTech.com Thunderbolt 3 to Dual HDMI 4K In Stock £110.54
CZCK StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £12.26
CZCK StarTech.com Thunderbolt 3 to Dual DisplayPort Adapter DP 1.4 - Dual 4K 60Hz or Single 8K/5K In Stock £79.49
