StarTech.com Thunderbolt 2 Dual-Video Docking Station for Laptops - 2x DisplayPort
Quicklinx: BV5YWS00 Mfr#: TB2DOCK4K2DP
Transform your MacBook or laptop into a dual-monitor workstation, or connect a single 4K Ultra HD display. This Thunderbolt 2 docking station for laptops is one of the first Thunderbolt 2 docks to support dual DisplayPort video output. With 20Gbps data throughput, it lets you connect up to 12 devices to your MacBook or laptop, without sacrificing system performance.
Plus, it offers ports that are often missing on other laptop docks, such as eSATA and S/PDIF 5.1 digital optical audio.
This specialty laptop dock is a must-have accessory for a variety of environments, including home and office workstations, design studios, and on-site production applications.
This Thunderbolt 2 dock lets you connect two displays to your laptop using common DisplayPort monitors. Traditional Thunderbolt docks require that at least one of your monitors is a Thunderbolt display for dual video, which means you might need to spend extra time and money on the additional display. Because it offers two DisplayPort connections, the dock makes it easy to create a highly productive dual-video workstation, with no additional costs or inconveniences.
With dual displays, you have more screen space to manage several programs at once. You can work more efficiently by avoiding the nuisance of rearranging windows, or flipping back and forth between pages.
If you're looking to add a 4K Ultra HD display to your laptop, then this dock can help. The dock delivers vivid 4K (3840 x 2160p - 30Hz) image quality to a single DisplayPort or Thunderbolt monitor. And, because it supports DP++ you can connect a 4K HDMI display using a DP2HD4KADAP DisplayPort to HDMI Adapter (SKU: DP2HD4KADAP - sold separately). It's perfect for web and graphic designers, animators, or anyone who works with high-resolution videos and images.
Plus, you can connect a Thunderbolt display and a DisplayPort monitor while maintaining 4K resolution on the DP display. You can also connect multiple displays via a Thunderbolt daisy chain, giving you multiple options for expanding your viewing capabilities.
The Thunderbolt 2 docking station smashes connection limitations. It provides several peripheral ports, including the hard-to-find connections that are missing from most laptops and docking stations. Ports such as a built-in eSATA port and S/PDIF 5.1 digital optical audio output set this dock apart, making it easy to enhance or harness the storage and audio capabilities of your MacBook or laptop.
The dock also features an always-on USB fast-charge port, so you can quickly charge your smartphone or tablet even when your laptop is disconnected. And because it offers 20Gbps data throughput, the Thunderbolt 2 dual-video docking station lets you connect and use your peripherals at higher speeds. With faster device access you can save time and get work done more quickly.
StarTech.com Thunderbolt 2 Docking Station - Compatible with Windows / macOS - Dual Monitors - 2X DisplayPort - TB2DOCK4K2DP - docking station - Thunderbolt - 2 x DP, 2 x Mini DP - GigE
Docking station
Docking Interface
Thunderbolt
Video Interfaces
2 x DP, 2 x Mini DP
8.9 cm x 27.1 cm x 2.9 cm
544 g
Silver
Australia, North America, United Kingdom, Europe
Gigabit Ethernet
Power adapter AC 100/230 V
3-year warranty
P/N: ARMBARDUO, ARMDUAL, ARMDUAL30, ARMSLIMDUO
Docking station
8.9 cm
27.1 cm
2.9 cm
544 g
Enclosure Colour
Silver
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0
2 x Thunderbolt 2 - Mini DisplayPort , 2 x display / video - DisplayPort output - 20 pin DisplayPort , 4 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x eSATA - 7 pin external Serial ATA , 1 x audio - SPDIF output - TOSLINK , 1 x audio - line-out/microphone - mini-phone 3.5 mm 4-pole , 1 x microphone - input - mini-phone stereo 3.5 mm , 1 x network - 10Base-T/100Base-TX/1000Base-TX - RJ-45
1 x Thunderbolt cable - external
LED indicator, 1 USB 3.0 fast charging port
FCC, RoHS
Power adapter
AC 100/230 V
Microsoft Windows 7 / 8 / 8.1 / 10, Apple macOS Sierra 10.12
Limited warranty - 3 years
BV5Y StarTech.com StarStarTech.com Universal USB 3.0 Laptop Docking Station w/ Dual DVI Video In Stock £85.01
BV5Y StarTech.com Universal USB 3.0 4K Laptop Docking Station w/ 4K DisplayPort In Stock £93.33
BV5Y StarTech.com Triple-Video Laptop Dock In Stock £100.82
