StarTech.com Thunderbolt 2 Docking Station
Quicklinx: B27FWS00 Mfr#: TB2DOCK4KDHC
Transform your MacBook or laptop into a powerful 4K Ultra HD workstation or hot desk, through just a single Thunderbolt cable. The TB2DOCK4KDHC Thunderbolt 2 Docking Station lets you connect up to 11 devices to your MacBook or laptop, so you can create a convenient, 4K Ultra HD workstation. Laptops often lack the connection ports you'll need to maximize productivity, while many docking stations only offer basic port interfaces. With more connection ports than most docking stations, now you can vastly expand your connectivity while taking advantage of Thunderbolt 2 possibilities.
Delivering unparalleled speed and unprecedented display technology, the TB2DOCK4KDHC offers the ultimate in workstation convenience and is one of the first Thunderbolt 2 docking stations available.
Thunderbolt 2 redefines efficiency with dependable, lightning-fast performance. With up to 20 Gbps data throughput, this convenient laptop docking station helps you avoid the nuisance of bandwidth bottlenecks when connecting multiple displays and peripherals to your MacBook. Thunderbolt 2 merges two 10 Gbps channels, delivering speeds that are twice as fast as Thunderbolt 1, and 4x faster than USB 3.0, for unparalleled device performance.
With virtually no throughput restrictions, this versatile docking station gives you essential connection ports as well as interfaces other Thunderbolt 2 docks don't offer, such as USB 3.0 fast-charge, eSATA and SPDIF 5.1 digital optical audio ports. The TB2DOCK4KDHC lets you use your peripherals at higher speeds, saving you time so you can get your work done faster.
Discover 4K Ultra HD for an unprecedented visual experience! The dock delivers brilliant text and image quality at 4K resolution (3840 x 2160p) to your HDMI, DisplayPort, or Thunderbolt monitor. Plus, you're set for the future popularity of 4K sources and displays.
For the improved productivity of a dual monitor setup, the dock can connect to an HDMI and a Thunderbolt display, with 4K resolution on a single display.
You can even connect multiple displays via Thunderbolt daisy chain, giving you two convenient possibilities for expanding your overall screen real estate!
For a convenient workstation experience, you can eliminate hassle and save time by leaving your vital peripherals connected to the dock. You can easily create a dynamic, full-sized workstation in seconds using the included Thunderbolt cable. Plus, you can fast-charge your tablet or smartphone with or without your laptop connected to the dock, through a handy, always-on USB fast-charge port.
This Thunderbolt dock lets you hurdle connection limitations by adding several essential ports to your MacBook Pro or MacBook Air, such as multiple storage peripherals through eSATA (with port multiplier support) and USB 3.0 hub ports. Unlike other Thunderbolt docking stations, the TB2DOCK4KDHC offers an SPDIF port so you can take advantage of your laptop or MacBook 5.1 digital optical audio capabilities. Plus, for maximum connectivity you can daisy chain up to 6 Thunderbolt devices.
This durable Thunderbolt 2 dock also features an aluminum outer frame and stylish silver sandblast finish that matches your MacBook nicely!
  • Unparalleled Thunderbolt 2 performance
    Thunderbolt 2 redefines efficiency with dependable, lightning-fast performance. With huge data throughput, this convenient laptop docking station helps you to avoid the nuisance of bandwidth bottlenecks when connecting multiple displays and peripherals to your MacBook. The TB2DOCK4KDHC lets you use your peripherals at higher speeds, saving your time so you can get your work done faster.
  • Unprecedented display technology
    Discover 4K Ultra HD, for an unprecedented visual experience! The TB2DOCK4KDHC delivers brilliant text and image quality at 4K resolution to your HDMI or DisplayPort monitor. The Thunderbolt 2 dock lets you connect dual displays to your MacBook. The dock offers dual monitor support when connected to an HDMI Thunderbolt display. You can even connect multiple displays via Thunderbolt daisy chain, giving you convenient possibilities for expanding your overall screen real estate.
  • Ultimate workstation convenience
    For a convenient workstation experience, you can eliminate hassle and save time by leaving your vital peripherals connected to the dock. You can easily create a dynamic, full-sized workstation in seconds using the Thunderbolt cable. Plus, you can fast-charge your tablet or smartphone with or without your laptop connected to the dock, through a handy, always-on USB fast-charge port. The TB2DOCK4KDHC offers an SPDIF port so you can take advantage of your MacBook digital audio capabilities. Plus, for maximum connectivity you can daisy chain up to 6 Thunderbolt devices.
StarTech.com Thunderbolt 2 Dual Monitor Docking Station - HDMI - docking station - Thunderbolt - HDMI, 2 x Mini DP - 1GbE
Docking station
Docking Interface
Thunderbolt
Video Interfaces
HDMI, 2 x Mini DP
8.2 cm x 23.4 cm x 3.8 cm
470 g
Silver
North America, United Kingdom, Europe
Gigabit Ethernet
Power adapter AC 100/230 V
3-year warranty
P/N: ARMPIVOT, ARMPIVOTE, ARMPIVSTND, ARMSLIM, ARMUNONB, LTLOCK, SVA12M5NA
Docking station
8.2 cm
23.4 cm
3.8 cm
470 g
Enclosure Colour
Silver
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0
2 x Thunderbolt 2 - Mini DisplayPort , 1 x display / video - HDMI - 19 pin HDMI Type A , 4 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x eSATA - 7 pin external Serial ATA , 1 x audio - SPDIF output - TOSLINK , 1 x audio - line-out/microphone - mini-phone 3.5 mm 4-pole , 1 x microphone - input - mini-phone stereo 3.5 mm , 1 x network - 10Base-T/100Base-TX/1000Base-TX - RJ-45
1 x Thunderbolt cable - external
Security lock slot (cable lock sold separately), LED indicator, 1 USB 3.0 fast charging port
FCC, RoHS
Power adapter
AC 100/230 V
Apple MacOS X 10.9 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years
B27F StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.12
B27F StarTech.com 3.5mm 3 Pin Headset Splitter In Stock £6.39
B27F StarTech.com 3m (10 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £15.35
B27F StarTech.com StarStarTech.com Universal USB 3.0 Laptop Docking Station w/ Dual DVI Video In Stock £85.01
B27F StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 In Stock £76.92
B27F StarTech.com Universal USB 3.0 4K Laptop Docking Station w/ 4K DisplayPort In Stock £93.33
B27F StarTech.com Triple-Video Laptop Dock In Stock £100.82
