StarTech.com StarStarTech.com Universal USB 3.0 Laptop Docking Station w/ Dual DVI Video
PRICE DROP!
Last Few Remaining
Price Drop
Quicklinx: 9NYJWS00 Mfr#: USB3SDOCKDD
49 in stock
£137.96 ex VAT
£165.55 inc VAT
Standard delivery Delivered within 3-5 working days
Expand your MacBook, Ultrabook or laptop into a powerful office workstation or hot desk via a single USB 3.0 cable. This USB 3.0 Laptop Docking Station delivers display flexibility, fast charging, and desktop convenience to your home or office workstation. Using a single connection, the dock instantly adds two DVI ports plus HDMI and VGA adapters, a USB 3.0 hub with two quick-charge ports, Gigabit Ethernet, and a 3.5mm headset jack to your laptop.
It's the perfect accessory for virtually all USB 3.0 equipped laptops (for example, the Dell Latitude 13 7000 2-in-1, Microsoft Surface Pro 4, Surface Pro 3, or Surface Book).
Discover multi-monitor freedom! Boost your productivity by adding dual monitor support to your workstation with one of the only docking stations to offer dual DVI video ports each delivering resolutions up to 2048x1152.
For extra display flexibility two DVI video adapters are included, letting you avoid the frustration and costs of purchasing additional products just to fit the displays you already use. Leave the stress of interface limitations at the door by adapting to the most popular monitor types right out of the box. No hassle, no headaches. With a range of video output options, the dock is ideal for hotel desks or hot desks.
Charge your mobile devices faster, with or without a laptop connected to the dock. USB charging is convenient, fast, and accessible through two front "always on" USB fast-charge ports, combining data throughput with support for USB Battery Charging Specification 1.2 - You can simultaneously maintain work efficiency while adding charge and sync flexibility for up to two mobile devices (2 tablets or 1 tablet/1 smartphone).
Now, you can easily charge other devices while connected to multiple displays, a Gigabit network, and numerous USB peripherals through the integrated 5-port USB 3.0 controller. Perfect for external USB 3.0 hard drives, the docking station supports UASP-enhanced performance for faster data transfer rates, which means less waiting and more productivity.
Save time and get more work done! With a single connection to your laptop (e.g. MacBook Pro, MacBook Air, Lenovo ThinkPad, HP or Dell Ultrabook) your required peripherals remain connected. Overcome your laptop port limitations and reduce the hassle of constantly reconnecting devices, to create an organized and full-sized workstation with less clutter that's great for hoteling, or hot desking.
Plus, for a clean and customized workspace you can position the docking station in horizontal orientation, or upright (tower), using the included optional stand.
  • Display flexibility
    The dual-DVI docking station adds dual-monitor support to your workstation, with resolution support up to 2048x1152. With more screen space, you can simultaneously access multiple applications and reference material on one display while composing on the other. To ensure the USB 3.0 dock supports a variety of displays, two display adapters are included.
  • Powerful connections and fast device charging
    Transform your laptop into a workstation that supports all of your peripherals. This docking station features five USB 3.0 ports. The two front-facing USB ports are USB fast-charge ports. These accessible ports charge your mobile devices faster than standard USB ports, with or without your laptop connected to the dock. The dock also has a GbE port, headset jack and separate 3.5 mm audio and mic ports, so you'll have all the connections you need.
StarTech.com Dual Monitor USB 3.0 Docking Station w/ DVI to VGA & HDMI Adapters, 5x USB 3.0 & Audio - Vertical DVI Dock for Mac & Windows (USB3SDOCKDD) - docking station - USB - DVI - GigE
Docking station
Docking Interface
USB
Video Interfaces
DVI
2.4 cm x 8 cm x 18 cm
450 g
Black, silver
Gigabit Ethernet
Power adapter AC 100/230 V
3-year warranty
P/N: ARMBARDUO, ARMDUAL, ARMDUAL30, ARMSLIMDUO, TB33A1C
Docking station
2.4 cm
8 cm
18 cm
450 g
Enclosure Colour
Black, silver
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
5 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x SuperSpeed USB 3.0 - 9 pin USB Type B , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x headset / headphones / microphone - input / output - mini-phone 3.5 mm 4-pole , 1 x display / video - DVI-Digital - 24+1 pin digital DVI , 1 x display / video - DVI-Analog/Digital (dual link) - 24+5 pin combined DVI
1 x USB cable - 1 m , 1 x DVI-VGA adapter , 1 x HDMI-DVI adapter
4 x rubber feet, stand, 2 x stand screws, screwdriver
LED indicator, 2 x USB 3.0 charging port
FCC, RoHS
Power adapter
AC 100/230 V
Microsoft Windows XP (32-bit) SP3, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Apple MacOS X 10.6 - 10.12, Google Chrome OS 55 or later, Apple macOS Mojave 10.14
Limited warranty - 3 years
50 °C
9NYJ StarTech.com 15 ft DVI-D Dual Link Cable - M/M In Stock £13.08
9NYJ StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI GbE In Stock £48.85
9NYJ StarTech.com StarStarTech.com Universal USB 3.0 Laptop Docking Station w/ Dual DVI Video In Stock £137.96
9NYJ StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 In Stock £78.59
9NYJ StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £121.91
9NYJ StarTech.com Universal USB 3.0 4K Laptop Docking Station w/ 4K DisplayPort In Stock £140.19
9NYJ StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £9.71
9NYJ StarTech.com Docking Station for 2 Laptops In Stock £158.19
9NYJ StarTech.com Monitor Mount - USB Passthrough In Stock £149.16
9NYJ StarTech.com Dual Monitor Mount - Stackable In Stock £148.13
9NYJ StarTech.com Dual Monitor Stand In Stock £80.78
9NYJ StarTech.com Vertical Dual Monitor Stand In Stock £80.78
9NYJ StarTech.com Vertical Dual Monitor Mount In Stock £70.11
9NYJ StarTech.com Thin Client Mount - VESA In Stock £22.96
Stock Status: In stock
