StarTech.com Standalone Video Capture
Quicklinx: BKC1WS00 Mfr#: USB2HDCAPS
Capture high-definition video to a PC, or to an SD card without a computer, and stream live video over the Internet in real time. This high-definition capture device lets you record an HDMI or component video source, with audio, through a USB port on your computer.
With two standalone modes for recording or streaming, the capture device lets you record directly to an SD card for standalone capture, or use the built-in LAN port to stream video over the Internet.
This versatile capture device features an SD card slot, which lets you record video directly to a card without having to connect the capture device to your computer. It's the perfect way to save time, while adding support for non-Windows based platforms such as Mac computers or Android tablets. You can also record directly to your Windows based computer using the included video capture software.
For hassle-free video streaming, the capture box also has a built-in RJ45 network port that enables you to connect the capture device directly to your router or switch. With this standalone network connectivity you can instantly stream your video source over the Internet using online services such as Twitch .
The device encodes in H.264, the most widely adopted video codec in the world, so you can rest assured that your video captures will be compatible with almost any device platform with no editing or converting required. H.264 is also widely supported by most software titles including Adobe Premiere and Windows Media Encoder.
Plus, the included software lets you take screenshots, schedule recordings and instantly stream your video source over the Internet. The software is compatible with NTSC and PAL systems, which is perfect for professional video archiving applications where source media can change from project to project.
This device features one-key capture for simple push-button video recording using the included software, or push-button capture and streaming while in standalone mode. The built-in video pass-through ports enable real-time video review while you capture or stream content.
To maximize portability, the capture device is USB powered, so you don't have to use an additional power adapter or find an available wall outlet.
This USB video capture device will not record digitally encrypted content.
StarTech.com USB 2.0 HD PVR Gaming and Video Capture Card - 1080p HDMI / Component Capture Card (USB2HDCAPS) - video capture adapter - USB 2.0
Video capture adapter
Interface Type
USB 2.0
Video Input
S-video input, S-video output, composite video input, composite video output, component video input, component video output, HD-PLC, HDMI input
Analogue Video Format
NTSC, PAL-M, PAL 60
Analogue video Signal
S-Video, composite video, component video
Digital Video Format
MPEG-4, H.264
Audio Input Support
Standard
Interface Type
USB 2.0
Video
Interface Type
NTSC, PAL-M, PAL 60
MPEG-4, H.264
Audio Input Support
Standard
1 x display / video - component video input - RCA x 3 , 1 x display / video - S-video input - 4 pin mini-DIN , 1 x audio - line-In - RCA x 2 , 1 x display / video - HDMI input - 19 pin HDMI Type A , 1 x display / video - component video output - RCA x 3 , 1 x display / video - S-video output - 4 pin mini-DIN , 1 x audio - line-out - RCA x 2 , 1 x display / video - HDMI output - 19 pin HDMI Type A
1 x USB 2.0 - 4 pin USB Type A
1 x USB cable - external , 1 x component video cable - external , 1 x audio cable - external
FCC, RoHS
Software Included
Drivers & Utilities
BKC1 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.28
